Should a 308 tiptronic change down automatically in manual mode ?
Results 1 to 7 of 7
    Feb 2011
    New Zealand !
    173
    Icon5 Should a 308 tiptronic change down automatically in manual mode ?
    Hi
    I have a 308 2.0 HDi auto and noticed today when I took it for a short drive in manual mode [very rare] that when slowing down to a stop or give way sign that it would change down by itself e.g. if I was driving in M4 or M3 it would change down to M2 or M1 etc. I see this on the display
    Is this how it should work ?
    I ask as we had some warranty work done last Dec that required the gear box out and since that work we notice on occasion in auto mode [D] when coming to a stop there is a small 'donk' from the gearbox as it it has finished late changing down to 1 or disengaged the clutch
    Do I have a problem ?
    10,961
    Quote Originally Posted by xlink_nz View Post
    Hi
    If it might be a warranty item, and you are under warranty (the "small 'donk' from....", for example) I'd put it to them and get them to prove otherwise. Might be fine or might be precursor to trouble out of warranty. So why would you not go and ask the question?
    Then, others will give tech advice here to help your interrogation of the dealer.
    Good luck.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Feb 2011
    New Zealand !
    173
    Thank you for the reply
    Before I assume a warranty issue I'd like to know whether my auto gearbox changing down in manual mode as outlined above is normal
    What I can do is take another 308 auto [from the dealer] for a drive and see if it exhibits the same behavior in manual mode, if not then yes I can put it too the dealer
    Elsewhere
    49
    It is normal. The gearbox will override your selection to prevent under/over-revving the engine.
    From the manual:
    Quote Originally Posted by 307 manual, pp122
    It is only possible to change from one gear to another if the vehicle speed and engine speed permit; otherwise, the gearbox will operate temporarily in automatic mode.
    In the event of under-revving or over-revving, the gear selected flashes for a few seconds, then the actual gear engaged is displayed.
    When the vehicle is stationary or moving very slowly, the gearbox selects gear M1 automatically.
    Previous cars: 405 series 2 Mi16, 505 GTi sedan, 405 petrol wagon, 505 GTi Executive, 406 STDT sedan; Xsara VTS, C5 V6 Exclusive
    London, UK
    294
    I also found with my 607 that even in manual mode it won't let me use 100% throttle at low revs. The damn thing assumes that you are doing some kind of "emergency" accelerate and drops from 4 to 2 even though you didn't ask it to.
    It's a big torquey diesel and so I would like to waft around at 1500rpm or so and use all of that diesel torque. The gearbox just won't let me
    607
    607 is offline
    Member 607's Avatar
    Sep 2011
    Brisbane, Australia
    77
    Quote Originally Posted by dieselnutjob View Post
    Same applies to the petrol model. Go to slow in a gear and it will auto change down.
    Should get a life 2353's Avatar
    Brisvegas
    4,049
    Our 1.6 EGC Diesel also changes down automatically in Manual mode. So does our Renault Grand Scenic and the Mazda 6 we had prior to the Scenic. Have a read of the manual, it sounds like a version of adaptive control and probably also changes down if you're going down a hill and do more than touch the brakes.
    Save the earth, it's the only planet with chocolate.
