Hdi engine oil specs
Results 1 to 25 of 44
Like Tree5Likes
Thread: Hdi engine oil specs
    Oct 2005
    vic
    848
    Default Hdi engine oil specs
    Hi people,
    Normally live over in the Renault dungeon.
    Have purchased a 2007 TDCI non-DPF hatch for son.
    The diesel engine, Duratorque, I am led to believe is the PSA/DW family engine.
    What are the engine oil specs for it as required by Pugs/cits?
    The ford engine oil spec is M2C 913B is not often quoted on oil specs available aftermarket.
    Know you guys are pretty hot on Total/Elf.
    Am after a specification cross-reference. I suspect a mid-saps ACEA C3 5W30 will do the trick.
    Just after confirmation/web sites leading to specs.
    Thanks,
    David
    May 2001
    Sydney, NSW, Australia
    3,634
    The oil you should run is Total Quartz INEO ECS. It is about $100 at Peugeot/Citroen dealers.
    http://www.peugeot.com.au/media/deli...305-df583b.pdf
    The easiest to find WSS-M2C 913-B Ford-spec oil is Liqui-Moly LEICHTLAUF SPECIAL | 5W-30 (made in Germany). It is $60 at AutoOne and Autobarn.
    268
    Ford WSS-M2C 913-B, superseded by WSS-M2C 913-C
    Traditional high-SAPS oils, lower HTHS limit of <3.5, based on ACEA A5/B5.
    Oils which meet the more recent C-spec include:
    • Caltex Havoline Energy 5W-30
    • Castrol EDGE Professional A5 5W-30
    • Mobil Super 3000 X1 Formula FE 5W-30
    • Motul 8100 ECO-negy 5W-30
    • Total Quartz Future NFC 5W-30
    Though I don't think I've ever seen these particular oils on shelves.
    Ford WSS-M2C 934-A and WSS-M2C 934-B
    Low-SAPS oil, lower HTHS limit of <3.5, based on ACEA C1
    I don't think these lubricants are necessary for your DPF-less engine.
    PSA B71 2290
    Mid-SAPS oil, lower HTHS limit of <3.5, based on ACEA C2.
    Specified for all Peugeot/Citroen HDi engines with a DPF.
    Oils approved to this spec include:
    • Castrol Magnatec Professional C2 5W-30
    • Fuchs Titan GT1 Pro C2 5W-30
    • Mobil Super 3000 Formula P 5W-30
    • Motul 8100 ECO-clean 5W-30
    • Total Quartz Ineo ECS 5W-30
    I haven't seen these particular oils on shelves either, though you can buy the Total oil from Peugeot or Citroen dealers.
    ACEA C3
    Mid-SAPS oil, but with a higher HTHS limit of >3.5 (which means it's a bit thicker, so more drag, less efficient).
    • Mobil 1 ESP Formula 5W-30
    • Shell Helix Ultra Extra 5W-30
    • ... and many more
    May 2001
    3,634
    Quote Originally Posted by Diesel_vert View Post
    Castrol EDGE Professional A5 5W-30 - only available in 200L drums I believe
    Total Quartz Future NFC 5W-30 - not imported into AU
    Mobil Super 3000 X1 Formula FE 5W-30 - unable to find stock in AU.
    PSA B71 2290
    Total Quartz Ineo ECS 5W-30 - easily available at Peugeot dealers, but expensive...
    Note that none of the Castrol Magnatec 5W-30 that you find on the shelves in the Sydney auto stores is the "Professional" or "Edge Sport". The new Edge Titanium does not meet the required specs.
    Oil is complex these days
    Oct 2005
    vic
    848
    Thanks guys.
    Know all about complexities of motor oils - now have 3 diesels in the house from 3 manufacturers. Ford, Renault, & VW.
    Using this tool here have had a look at the RELATIVE performances of the ford spec (913C) the Pug spec (B71 2290) the VW spec 504/507 and generic C3.
    For the VW have been using Liqui-Moly, however it's not on special from Autobarn here in Vic.
    The VW camp is anal about oil companies 'meeting specs' and oil being certified by VW as meeting spec!
    Prefer not to get an oil that is stocked at dealers only usually means $$$$
    Looking at the 913 spec it SEEMS inferior to all.
    Would like a generic C2 or C3 that is available at REPCO to get the discount. Have decided on this oil change to try NULON 5W30 Synthetic Long life diesel oil that meets C2, C3 and Ford spec.
    However, looking at the tool VW 504/507.00 may be the ticket. Does all well but not as clean as C3.
    There is also the thoughts out there that you should throw economy to the wind and get a heavier oil 5W40 vs 5W30 in interests of mechanical longevity - not Penrite 5W50 style though.
    Any other thoughts - oil discusions?
    David
    268
    Quote Originally Posted by 85Fuego View Post
    Thanks guys.
    David
    Renault RN0720 (oil spec for diesels equipped with a DPF) is a low-SAPS oil, loosely based on ACEA C4. According to the datasheet of Mobil Super 3000 Formula R 5W-30 (a RN0720 spec oil not available here) it contains 0.5% sulphated ash and 0.05% phosphorus. This oil is probably okay for your Focus, but probably not suitable for a VW TDI PD engine (amongst other reasons).
    Not all 504/507 oils are equal. If it meets ACEA C2 or C3 (i.e. mid-SAPS oils), then the level of SAPS may be too high for the Renault, as per RN0720.
    No 5W-40 oil has 507.00 approval, and the level of SAPS in a 5W-40 505.01 oil (spec for VW TDI engines without a DPF) would be too much for the Renault, as per RN0720.
    I'd use Penrite Enviro+ 5W-30. Why?
    • It has been officially approved by VW (not a cheap exercise) to standard 507.00, which backwards compatible with 505.01.
    • It has also has approvals for MB 229.51 and BMW LL-04 (just a nice bonus is all).
    • Even though it meets 507.00, it's much closer to being a low-SAPS oil like Renault RN0720, which is ideal for the Koleos' DPF.
    • Likewise, the level of sulphated ash (0.6%) and phosphorus (0.06%) indicates it's more of a mid-low SAPS oil (closer to ACEA C1/C4 limits, and it's also why it doesn't meet ACEA C2/C3).
    • It has a HTHS of >3.5 as required for the Koleos and Golf, as per RN0720 and 507.00.
    • It's acceptable to use a high HTHS oil in an engine calling for a low HTHS oil, but not vice-versa. So the Focus is taken care of.
    • It's available in retail stores.
    Quote Originally Posted by DeKa View Post
    Only if you happen to own three modern diesel vehicles that call for such disparate oil specs that makes it technically impossible to be fully compatible with each other.
    Oct 2005
    vic
    848
    Thanks Diesel_vert,
    You are correct, would have been lovely to run one oil in all, but socialism in oil circles isn't allowed.
    Am actually running Penrite Enviro+ 5W-30 in the Koleos - it's somewhat of a pain because of a 7.5L sump capacity (you get 2 oil changes out of 3 x 5L jugs).
    Seems to be doing the job. Gets 8L/100k in urban conditions.
    Run Liqui-Moly Top Tec 5W40 in the Golf. Has been going well now for 7 years. All sorts of horror stories of cams going belly up in the US but not here?
    Gets 6L/100k in stop start traffic.
    The Focus drives well is a different feel of diesel/clutch combo. Relaxed - not as peaky as the Koleos.
    Will keep my eyes open for '20% off RACV Specials'.
    Thanks for the thoughts - good to see I'm not the only one 'peeking outside the box' oil wise!
    David
    Jun 2011
    Ballarat
    537
    Default Penrite Enviro+ 0W 40
    I used Penrite Enviro+ 0W-40. Why? Because it was the only oil I could purchase in 5Lt plus the 1Lt containers, and I needed 5.25Lt for oil & filter change and didn't want to purchase 2 Qty 5Lt containers. I have used it in my 2.0 HDi 307. It is a mid SAP oil. I would have preferred the 5W 30 but couldn't source it easily.
    London, UK
    294
    strange
    I have two HDIs, a 2.0 litre 8 valve and a 2.2 litre 16 valve.
    Both only need 4 1/2 litres to get to the max mark on the dipstick after an oil and filter change
    268
    Quote Originally Posted by dieselnutjob View Post
    strange
    Yep, the oil capacity of the DW10TD (2.0 90 HP) or DW10ATED (2.0 110 HP) is 4.5 litres and for the DW12TED4 (2.2 136 HP) it's 4.75 litres.
    However, the DW10BTED4 (2.0 136 HP) needs 5.25 litres.
    Fellow Frogger! Ceenine's Avatar
    Devonport, Holiday Coast
    498
    I use Penrite Enviro+ 5W-30, so hopefully the dpf will not gunge up any time soon. It is easy to source at Autobarn. Having said that, the local store in Devonport has just gone bust. I must try Supercrap which is unfortunate as it is a lowly retail experience.
    2014 C5 2.2 HDI Limited Edition Sedan
    2007 C5 2.2 HDI Hatchback
    2007 C4 1.6 HDI EGS Sedan
    Peugeot Mi16 Series 2
    May 2004
    Melbourne, Australia
    228
    Shell Helix Ultra Extra 5W-30 , 5 litre, is currently on sale at Repco. $49. ( normal price $75 )
    (ends 21st October 2012.)
    spiz
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    364
    Try using one of these links to search for the oil that suites you car.
    http://lubematch.shell.com.au/search...age=5&brand=67
    http://www.datateck.com.au/lube/valv_auMS/
    Or search google for a lube guide from the supplier of your choice.
    Fellow Frogger! Psychlone's Avatar
    Apr 2011
    252
    Total Quartz Ineo ECS 5W-30 was $75 about 3 months ago at Melbourne City Peugeot.
    May 2004
    228
    Quote Originally Posted by Psychlone View Post
    On my last service at Melbourne City Peugeot the oil used was Shell Helix Ultra Extra 5W-30, hence the Repco deal suits well.
    Sep 2003
    North Parramatta
    3,997
    Trivett Parramatta's Parts mob wanted to charge me $113 for it two months ago.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Jun 2012
    35
    This is the new one 5w-30w from Penrite I've used on my 2007 307 2lt turbo HDI with FAP. It's full synthetic maximises DPF life, low sap and cheap enough from Supercheap, around $58 for 5lts and cheaper when on they go on sale. And it comes in 1lt as well
    http://www.penriteoil.com.au/engineo...id_products=12
    Cheers George
    1000+ Posts N5GTi6's Avatar
    1,101
    Quote Originally Posted by Spiz View Post
    On my last service at Melbourne City Peugeot the oil used was Shell Helix Ultra 5W-30, hence the Repco deal suits well.
    I hope your dealer is not putting that oil in a DPF equipped HDi powertrain. I'm pretty sure that's not C2/C3 rated. You need to go to Ultra Extra to get the C2/C3 rating.
    http://lubematch.shell.com.au/recomm...age=5&brand=67
    Justin
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
    May 2004
    228
    Quote Originally Posted by N5GTi6 View Post
    Justin
    The dealer used Ultra Extra, was a typo in my post. & the Repco deal is for Ultra Extra.
    spiz
    Feb 2002
    Tamworth NSW
    496
    Just replying as another user of the Penrite Enviro+ 5W 30. The earlier Penrite equivalent for DPF engines was HPR 0, but that has now been replaced by the Enviro+ range.
    This oil suits both our 2.2 Hdi 4007 vehicle as well as the 407 SV Hdi V6 turbo diesel. The recent dealer price for the Total equivalent was $92.00. As a long term user of Penrite oils, I have total confidence in their product.
    K
    Quote Originally Posted by Whippet View Post
    16,484
    There's a nulon oil sold in 5 and 10litre drums at your local supercheap and autobarn that are 5-30, low ash, designed specifically for european diesels. About $120 for 10litres from memory.
    seeya
    Dec 2010
    33
    seeya
    Any one recommend this oil. I am about to do a oil change on my 407 Hdi V6 and am thinking of either Nulon Full Synthetic 5W-30 EURO Engine Oil or Penrite Environ DL-1.
    Mar 2011
    Linton.Victoria.
    1,235
    If you go to the Penrite Factory in Bayswater you will get a good deal according to the Penrite guy who spoke @ the P.C.C.V. Meeting recently-Do not think you have to have a Club Membership but would not hurt to take it with you if you have one.
    Do not know about other states.
    Dec 2010
    33
    For the record, I ended using Penrite oil but not FL-. Repro don't stock, not is it their Penrith book. I used enviro+ 5W -40.
    Car likes the change
    Sent from my GT-I9210T using Tapatalk 2
    lost
    11,055
    Icon6
    Quote Originally Posted by SLC206 View Post
    G'day,
    as well as being the most difficult to go to and fro, they are very expensive.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
