405SRDT Air Con problem
Results 1 to 3 of 3
    Jan 2012
    abermain n.s.w. australia
    19
    Default 405SRDT Air Con problem
    The fan blowing cold air ifrom the dash vents was working perfectly until it stopped when I was driving on a bumpy road. Compressor working . Light showing and still a trace of cold air there but not being blown into the cabin. Checked the fuses and all ok.. Any suggestions appreciated.
    tweed heads
    1,497
    Default that fan
    is above the passengers feet under the dash ,it has a multi pin plug that inserts from the bottom, its not uncommon for it to come loose and Drop out ,[bumpy road ] try shoving it back in ,three screws and the whole fan comes out ,theres usually a lot of crud up there built up over the years so clean that out and a little inox on the bearings it a big help ,theres a pc board on the fan housing that has to do with speed control ,i have a cure for dry joints there ,but first see how you go with just shoving it back in .PUGS
    Jan 2012
    19
    Thanks . Will do.
