Timing Belt Replacement on 1.9 litre Mi 16
    Apr 2012
    sydney australia
    17
    Icon5 Timing Belt Replacement on 1.9 litre Mi 16
    My car last had its timing belt replaced about 4 years ago but has only done about 38,000 kms since then.
    I would like some advice whether the critical factor is age of the belt rather than distance covered between belt changes; I understand that the recommended distance interval is 80,000 kms.
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,865
    Rubber perishes with age - so for safety, replace it!
    2005 Renault Clio 182 Cup
    1,376
    Quote Originally Posted by STALLED View Post
    +1 Here I don't like the though of replacing valves for the sake of a days work. (Enthusiast here, not mechanic)
    Much easier to keep the belt, waterpump & tentioner bearing in tip to shape.
    Mar 2011
    Linton.Victoria.
    1,235
    Four years or 80,000 K's-whichever comes up first.
    Presumably that relates to the fact that av. k's per year is 20,000 k.
    Much dearer to fix when it's broke & it will- should be that you are a little broke will ensure that you are even 'broker if she brakes.
    Not wise to be 'Pound wise & Penny Foolish' BUT I have found that most people who have cars with cam belts are blissfully unaware that they need changing.
    Was in some friends Car a while ago -I asked 'have you had the cam belt changed since you bought the car-'What is that & why does it need changing.NEVER KNEW.
    Had it @ least 7 years & done at least 200,00 k,s AND THE BELT HAD NOT BROKEN!!
    Needless 2 say he only drove it home & to his local garage.
    Never hurts to ask.
    Pekay.
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,012
    when you do change it do everything. when i bought my 405 1.9 mi16 ($1100 with 10 months rego ftw!) the original owner said the timing belt had snapped on her a short while ago, it was all sorted..apparently.
    when i went to change the belt to do the conversion into the 205 the belt had almost gone again, and had only done 3000km! mechanic must have got a timing belt kit but be careful, kits ive seen online only come with one tensioner...the car has 2. one was brand new one was 1 ball bearing away from collapsing
