505 wagon creaky stabiliser bar bushes
    Aug 2011
    42
    Default 505 wagon creaky stabiliser bar bushes
    Does anybody have advice regarding how to stop the creak from the front stabiliser bar bushes on a '92 505 wagon. It drives me absolutely nuts !!! The bushes seem to be polyurethane or a hard nylon material. They were replaced recently and are original equipment. I have tried using "superlube" synthetic grease but the noise comes back after a month or so. Any help would be most appreciated.
    8,426
    Quote Originally Posted by wagon505 View Post
    Wrap the bar with teflon tape, also known as Plumbers thread tape.
    Jo
    1000+ Posts Beano's Avatar
    3,149
    It _IS_ irritating, isn't it ? I greased mine (sedan) and it fixed the problem.
    They are the only flexibush in the front end of a 505 on which it is ok to put grease. If by chance the teflon tape
    (good idea !) doesn't work, you could try a different grease. Did you spray it in, or take off the metal plate and actually smear it in there ?
    8,426
    A few years ago when I stocked up on polyurethane bushings from noltech, they recommended and supplied molybdenum disulfide lithium based grease.
    Jo
    Aug 2011
    42
    Thanks,
    Yes I did remove the bushes and cleaned up the bar with wet and dry before greasing them. Noise went away and then came back. Think I might try the teflon tape idea.
