gti6 gear box in a mi16?
Results 1 to 7 of 7
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,333
    Default gti6 gear box in a mi16?
    will it work. My biggest questions are how different are the gear linkage seat ups?
    Will it clear the rack (unlike the 306) I think it should as the engine bay is bigger.
    And how do you hook up the pull up reverse? I could use an early 405 be1 type gear lever but which cable could I use and how do you disconnect the cable with from the gearbox?
    Cheers Chris
    2017 Renault Koleos auto
    7,483
    Yes, use BE1 setup.
    Romsey, VIC
    2,333
    Will the cable from the mi16 fit in the gti6 box? and be long enough?
    7,483
    I believe so:
    http://forum.405mi16.com/index.php?s...874&#entry5874
    You do it and let me know how it goes. I've got a 6 slot box here ready.
    Romsey, VIC
    2,333
    just did some research on the job and found chassis modification is required so no longer a thought. Don't wanna cut a hole in the car!
    12,266
    Quote Originally Posted by cav91 View Post
    where and why the cut ??
    you may find it may just be the plastic inner liner you need to cut back to allow the box to stick out into the wheel arch a little
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Romsey, VIC
    2,333
    Apparetly the inside of the chassis rail. Where the plastic inner guard clips on to, but the inside of it! The end casing of the gearbox sticks out and rubs slightly on the tyre when on full lock. Apparently rims off set out further or spacers will stop this.
