205 GTi will not start. was working fine but died whilst stopped at lights.
Results 1 to 23 of 23
    Fellow Frogger! WhiteKnightGTI's Avatar
    Apr 2012
    148
    Default 205 GTi will not start. was working fine but died whilst stopped at lights.
    Hi, i was driving my pug a few days ago and i was stopped at the lights when it suddenly died. I managed to start it back up again fine but i had to keep the revs up as it felt like it was going to do it again. I made it up to the shops and left the car for 10 minutes, then tried to start it again and it wouldnt do it. The battery is fine, the starter motor is also fine.
    Does anyone know what this could be? fuel pump possibly?
    1,376
    I would concentrate on the ignition module - Looks like a big black chip near the brake booster.
    Sometimes when they get old, they start to "cut out" when are hot. When cold, you would suspect every thing is ok.
    Look to see if there is lots of heat sink compound between the chip and the aluminium plate its mounted on, and good (non corroded) connections to it.
    Good luck,
    Mark
    Apr 2012
    148
    Quote Originally Posted by PugMonkey View Post
    Good luck,
    Mark
    Ok thanks. the engine was running cold at the time, i had only been driving for about 5 minutes if that. The ignition coil on the other hand looks like it hasn't ever been replaced. A friend experienced the same symptoms with a different car and it turned out to be the coil, so im thinking this may be the culprit
    1000+ Posts gezza's Avatar
    Bunbury
    2,191
    I would be checking coil first...
    Melbourne Australia
    1,382
    I'd also check coil lead from distributor as well as it will cause the same symptoms.
    Apr 2012
    148
    I've ordered a new coil from the UK. Hopefully it will be the end of my troubles for another month or so (i doubt it). Here's what i got if anyone can confirm that its the right part:
    http://www.ebay.com.au/itm/Peugeot-2...ht_4696wt_1108
    Ill have a look in the next couple of days to check the leads and so on
    Fellow Frogger! chez00's Avatar
    567
    Can I ask why you bought that coil from the uk? A genuine Bosch coil is inexpensive here and would be a far superior quality unit.
    1988 205 GTi XU10J4
    2001 406 Monaco 5sp V6
    1000+ Posts djvu205's Avatar
    1,402
    I priced a bosch coil a while back and from memory was around $250 +
    567
    Wow maybe I got a price on the wrong one! I was quoted $70 from memory. I didn't mention Peugeot though, that usually scares people and triples the price. MSD have direct replacements for about the same price, too, which I ran before I went to my current twin coil set-up.
    1988 205 GTi XU10J4
    Apr 2012
    148
    Ok so i fitted the ignition coil and it didnt solve the problem. I finally decided to take her to the mechanic to get them to have a look. They fitted a new distributor cap and cleaned up some dodgy connections, and it worked - for a day. I drove the car for 10 minutes then stopped, then went to start it an hour later and it wouldnt do it. Same problem as before, the battery turns over and everything, it just wont fire. She started fine that morning though, which leads me to think that is has to be a fuel related problem, a blockage in one of the leads or the fuel pump possibly?
    Anyone got any suggestions?
    Max
    Bunbury
    2,191
    What about changing the fuel filter as a pre-caution anyway??
    1000+ Posts dino's Avatar
    Nov 2002
    4,606
    fuel relay?
    Front left corner...
    dino
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    I dont believe you can get the original bosch oil coils anymore NEW. They opt for the small expensive ones. According to my auto elec. Though you can get the good ones off old ford lasers or telstars at a wreckers.
    As all of the above suggested - work backwards from the dizzy to the coil module plug.
    Then things like your fuel pump relay, cold start valve, plugs & leads. surely its one of them if it was going....then not.
    best of luck
    Dec 2010
    Greenleigh NSW
    74
    Tachymetric controller is likely cause; the subject of many former threads. A little searching should provide the detail.
    Nov 2011
    Wentworth Falls
    23
    I suspect the fuel pump. I had very similar symptoms when my R17 Gordini pump wore out.
    If you can't hear the pump run and then stop, when you turn on the ignition, it's almost certainly the pump.
    Good luck,
    Tony
    Apr 2012
    148
    Quote Originally Posted by monteman View Post
    Thanks, I'll have a look at that. There was some wiring around the ignition module that a previous owner did a terrible job of trying to repair so i had that fixed and replaced the module while i was at it. It fixed it and i drove it for a day then began driving it again this morning and it started fine then it cut out on me after about 10 seconds of driving and wouldnt start again. Does this narrow it down to any other suggestions? I intend to replace the fuel pump and filter. Possibly the ECU?
    Fellow Frogger! le frogg 205's Avatar
    canberra city australia
    394
    wats about the vaccum lines between the air flow and the throtle body !or the oil filler?
    Dec 2010
    Greenleigh NSW
    74
    It took months for me to find the problem with my tachymetric controller: it was heat sensitive due to a dry joint and only a magnifying glass and careful wriggling of each component pin-pointed the problem. A one second touch of the soldering iron and the problem was fixed.
    Nov 2002
    4,606
    I just swapped it over... the relay was very temperamental... boys at reagans couldnt figure it out. Eventually i went to the renault and pug wrecker out the west somewhere and they just let me swap bits over till I got the bugger sorted... turned out to be the tach relay... its the relay that cuts power to the pump in case of an accident...
    dino
    9,008
    Are you talking about an internal solder joint? I mean you opened the tachy relay and found the cold joint inside?
    ACHTUNG ALLES LOOKENPEEPERS
    Dec 2010
    Greenleigh NSW
    74
    Yes. Superannuants resort to fundamentals.
    9,008
    Thank you. And well done! Excellent philosophy.
    I used to do that with flasher relays on R12 but since given up because I have now a stash of good ones. I was a bit reluctant to open a tachy relay because I wasn't sure they can be opened and didn't want to destroy the only one I have. I'll dive in next time I suspect it. Does the 205Si have an interchangeable relay with the GTI?
    Dec 2010
    Greenleigh NSW
    74
    Graham Wallis may be able to answer that. The interior of the tachymetric controller is not particularly threatening; in fact the cover pops off easily. The little relay inside has a tendency to burn its points a little, so I ground a thin file to about 4mm wide to touch it up on a regular basis. It was only after I was satisfied that this was not the (obvious) problem, I went looking for a dry joint et voila.
