206 Gti 180 Gearshift link installation
Results 1 to 3 of 3
    Dec 2010
    Central Coast NSW
    32
    Default 206 Gti 180 Gearshift link installation
    The gear lever in my 180 is a bit loose in 5th , and not selecting smoothly in other gears.
    Been told that the nylon bushes Gearshift link are worn and needs replacement, Item 7 in the picture below.
    Does anyone know the procedure for aligning the gear lever to the gearbox anfter the link is replaced?
    TIA
    Dave
    Sep 2003
    North Parramatta
    3,997
    Your picture link didn't come through...
    Item 7 is a fixed link, so probably not much drama. I fitted quite a few quickshift links on the regular 138 and I didn't need to align anything.
    The cables on the 180 (item 2 & 3), however are adjustable.
    I have no idea how they are adjusted on a 180 so I won't offer anything, other than if you don't adjust the cables it should be ok.
    There are other things that could cause the issue, though. Is the hydraulic clutch ok? Is there plenty of brake fluid? How sure are you that it's a gearbox link that's the problem?
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Dec 2010
    Central Coast NSW
    32
    Simon
    Thanks for fixing the picture, the clutch was only replaced 6 months ago and it was the mechanic that suggested the gear link was on its way out. He suggested to do it myself.
    Just looking for a bit of advice before taking the plunge
    Dave
