our 505 executive
Results 1 to 24 of 24
    Feb 2001
    Romsey, Victoria, Australia
    4,864
    Default our 505 executive
    Our 505 executive in our "to good to wreck" page is almost sold pending we can get the sun roof working properly.
    Anyone got any ideas?
    It works but is very slow, we've greased and lubricated the tracks and replaced the motor in the boot and tried another switch.
    What else is there?
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,865
    How much current is the sunroof motor getting?
    2005 Renault Clio 182 Cup
    Feb 2001
    4,864
    Quote Originally Posted by STALLED View Post
    Just went and checked that. It has 12v at the motor with the engine off and about 13.5 with it running.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Dec 2002
    Menzies Creek
    2,541
    David, that doesn't tell us much. We really need to know what voltage is at the motor terminals while the motor is being operated. Putting an ammeter in line with it would also tell us how much current the motor is drawing.
    My concern is that the motor you have put it may not be any better than the one you put in. Most of them are tired by now.
    The other thing that gets a bit tired is the cable itself. They have a grease inside them that over the years goes a bit 'chewy'. You need to pull the roof lining out to get to it though. You can try forcing some spray grease or 'CRC' up the cable, but you run the risk of it spilling inside the roof lining and making a mess.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    12,265
    i use silicon spray on the runners of the 604, makes it work a lot better than grease. slipperyer (new spelling )
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Northern NSW
    1,075
    The cable inevitably breaks. Ask me how I know.
    London, UK
    294
    are the 505 and 604 roof mechanisms the same or different?
    Fellow Frogger! Molerpa's Avatar
    Jul 2005
    South America, Argentina, That country that looks like hanging from the map... just about to fall...
    492
    As far as I know (and I had both, still have 505) absolutely different. 505 is cable operated, and the motor is on the boot, right (passenger) side, behind the side covers, inside of the fender (don't know if the term is correct).
    On the 604, the motor goes inside the roof, on the middle of what is between end of sunroof and end of roof (rear windshield), and is rack and ... not pinion, the other one, that is like a endless thread, don't know its name.
    If broken, on the 604, you can disconnect the rack and operate by hand. On the 505 not.
    Quote Originally Posted by luthier View Post
    It is simply impractical to expect a petrol motor to get through too much water. That's why God invented diesels.
    12,265
    Quote Originally Posted by Molerpa View Post
    that's right
    but the roof slides better on the runners (they both have these) if silicone spray is employed instead of grease
    1 x 2018 3008
    Jul 2005
    492
    still I remember a little of that great car I had...
    Fellow Frogger! julian b's Avatar
    Aug 2011
    hawthorn melbourne
    482
    Why did peugeot change from the simple manual sunroof used on the 504 that nothing much could go wrong with .
    Feb 2001
    4,864
    Quote Originally Posted by julian b View Post
    Ha ha your starting to sound like us,
    My fathers favorite saying. They had it right once, then they improved it, now look at the mess we're in.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Feb 2001
    4,864
    Thanks for your imput Molerpa but one thing to remember that might confuse us simple Aussies. Our cars are right hand drive so the sunroof motor is on the drivers side not the passengers.
    Hey, people here can't work out which is left and right on there car, drivers side and passenger side is sometimes the only way to get through to them.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Feb 2001
    4,864
    Quote Originally Posted by Demannu View Post
    Yeah both motors spun at the same speed on a battery, maybe thats all it is, maybe we need a third motor. I'll try some silicone grease down the tracks but I'm not pulling the head lining out.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Dec 2002
    Menzies Creek
    2,541
    Quote Originally Posted by David Cavanagh View Post
    The problem is that they're probably all going to be slow. The brushes in the motor gum up and don't make good contact with the commutator, and the gaps in the commutator build up with carbon dust from the brushes, effectively partially shorting out the rotor. I pulled one apart yeeeeeears ago and cleaned it all up and it was great again, but I don't really remember how much of a pain it was to do it. Could be simple, could be more trouble than it's worth.
    Scotty
    Jul 2005
    492
    When I red this, I felt the most stupid on the entire world.
    And... I entered back here just to correct that... too late.
    Feb 2001
    4,864
    Don't worry about it your not the most stupid in the entire world. I'm in the motor trade I could write a book about stupid people.
    A qualified mechanic rang looking for a gearbox for a 4wd Renault Scenic and he asked if 2wd was the same
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Feb 2001
    4,864
    Chris (CAV91) my son has one motor pulled apart now and is cleaning it out. It seems to spin better on the bench.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]m
    Jul 2005
    492
    Thanks,
    check the wire. Is easy to remove. Move the sunroof to the top closed position, then, remove cover, take 2 10mm nuts (or 11), remove clip of the wire, remove motor, turn by hand (I think counter clockwise), to release the 4-5 cm left on the gear. Then it is loose. Pull from it, remove it completely, clean (diesel would be the best) and grease it, but SLIGHTLY, or use teflon-based lubricant, and repeat it inverse order.
    Apr 2005
    866
    Hi David, what were you using as your earth point when taking that measurement, ie was the 12V across the motor terminals, or somewhere else? Just thinking it could possibly be a wiring issue rather than a problem with the motor. You could check the voltage difference between the motor -ve and a good earth point on the body, if it is good it should be zero or very close to zero. Note I have no experience with these motors
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    651
    So it must have been a massive pain then.
    504 GL Coupe '73 Silver
    407 HDi Sedan '05
    Dec 2002
    Menzies Creek
    2,541
    Quote Originally Posted by Uffee View Post
    Yes, I suspect I may have suppressed the memory!
    Scotty
    lost
    11,055
    Icon6
    G'day,
    for a more comprehensive list of stupid people, have a look at ...
    http://clientsfromhell.net/
    and you will see how really stupid some people can be..
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    Feb 2001
    4,864
    Quote Originally Posted by pug206gti View Post
    G'day,
    I can top that
    The same mechanic who asked about Scenic gearboxes also did this.
    This is another wrecking yard near us who do prestige cars. He asked for part for a 206 and I told him to get the VIN, we need to check the clients VIN.
    He rang back a few minutes later and said he'd checked the clients VIN against all the 206's in his yard and none matched and wondered if our did.
    I sat quiet for a second or 2 and thought, just as well they didn't, I wonder what would have happened if they did.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
