405 SRDT Injector pump leak???
Results 1 to 14 of 14
    Apr 2004
    Western Australia
    237
    Default 405 SRDT Injector pump leak???
    Hello , I suspect there is not an inexpensive solution to this problem but I live in hope??? My much loved 405 has developed a fuel leak on start up from cold. It drops about a cupfull of diesel on sthe first start up of the day. It then settles down pretty qickly and seems OK for the rest of the day. I suspect some sort of seal shrinkage or hardening in the Bosch injector pump. Is there an easy fix??/ Could it be something else?? Am I clutching at straws or is the beloved 405 best retired??? Any and all advice welcomed Thanks
    651
    Quote Originally Posted by glenough View Post
    Does it start promptly?
    504 GL Coupe '73 Silver
    407 HDi Sedan '05
    12,265
    you sure it's coming from the pump ??
    sounds like a filter O ring failure to me
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Apr 2004
    Western Australia
    237
    Default Both start promptly
    The car starts well after glowing without a problem at all. The leak also starts promptly and then seems to diminish quickly as well. I am assuming the leak is from the pump. Although I cant see anything from the top of ther engine. Where is this filter and its O ring situated??? Thanks for you help so far
    651
    It doesn't sound like your pump is stuffed. As Pugrambo says, it's probably the filter or the hoses to and from the pump.
    407 HDi Sedan '05
    Fellow Frogger! Monsieur 405's Avatar
    Sydney, Australia
    266
    unfortunately it's an inevitable problem for the SRDT. Something to do with ULSD destroying the seals... A once off change to trendy new seals will fix the problem once and for all... While you're at it overhaul the fuel pump...
    Monsieur 405
    Apr 2004
    Western Australia
    237
    Default Does Bio Diesel Help???????????
    I think I can remember reading somewhere on Aussie frogs that Bio Diesel will swell seals and help with leaks from the injector pump. Is this the case has anyone experienced this????
    Fellow Frogger! Roland's Avatar
    Perth
    727
    If it is the pump then you should expect a figure approaching $1,000 for a full overhaul.
    I recently had my nephew's car's pump overhauled and it was $600 labour plus parts. ($985 in total)
    Where is the leak coming from? Can you provide some pictures?
    Have someone watch when you start the car.
    tweed heads
    1,497
    Default pump
    before you start pulling things apart you need to find where the diesel is leaking from,seems a bit of a mystery that it leaks for a while then stops ,can you put some paper down under the car to try and locate where its coming from ,if it starts ok would seem that the suction side of the pump is ok [not loosing prime ]if its on the output side of the pump one would expect it to leak all the time it is running ,possibly the shaft seal on the pulley end of the pump ,keep us posted PUGS
    Mar 2012
    17
    No way shes retired yet! , the bosch pump will outlast the engine given the fuel filter is kept to date etc.
    At the top of the fuel pump rhs is a 10mm hose going to the intercooler, and just underneath is a 5mm bleed off hose going into a 4 in 1 junction.
    Check that it hasnt come off as it has no clamps and could be brittle after years of service.
    tweed heads
    1,497
    Default second that
    that bleed off line also daisy chains from injector to injector so any of those little pipes could be loose or broken ,get some from any diesel place PUGS
    Apr 2004
    Western Australia
    237
    Hello Thanks for the repliies It makes sense that it is a bleed of hose as the pump works fine. The way I figur it if there was leak before the pump it would suck in air and if after the pump it woulg spray pressurised fuel every where. The leak is from below the pump as from the top is clean and I can see nothing. I had the alternator changed recently. Could the mechanic have knock the hose off during the change over???
    Apr 2004
    Western Australia
    237
    Default What model Bosch pump??
    Hello can anyone advise what model Bosch Injector pump is used on a 1994 405 SRDT Thanks
    Mar 2012
    17
    It is a Bosch VE pump.
