warning light 407
    Sep 2011
    preston
    11
    Default warning light 407
    hi guys
    warning light keeps beeping on my 407 saying that indicator light fault,then at other times its brake light fault flashing up,have replaced all globes and all lights are operating as normal,but every time i press the brake pedal it keeps beeping,its sending me nuts any ideas would be greatly appreciated
    thanks George
    Dec 2002
    CANBERRA
    400
    I suspect this is the same problem I had, reporting a variety of faults in rear lights?
    If so the fix is an earth wire from the light assembly to the body near the light. I tried cleaning bulbs and connectors etc, sometimes with success for a while but finally gave up and went looking for a permanent fix.
    I just drilled the rear light circuitboard in a suitable spot on the earth side, made up a wire which I attached to the board with a self taper, and then connected the other end to a conveniently available 6mm bolt down on the body more or less directly below the light (slightly further into the boot).
    Worked a treat. I've only done one side yet but expect to have to do the other side sometime.
    email or pm me if you need more info.
    Hope it helps
    Jim
    Sep 2011
    preston
    11
    thanks for the reply will give it a go
    George
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    364
    Good to see Peugeot are consistent with there tail light faults across all model's.
    Fellow Frogger! Meggsy's Avatar
    351
    I don know where to locate it but there is a Peugeot Service letter about thgis problem especially if you have a tow bar fittted.
    Meggsy
    Current - 4007HDi
    Had - 407 HDI 406 SV 404, 504, 505 GR and STI. 405 GR ( carbie version) STI, MI16
    And an Austin 1800
    Learnt to drive in 203 Convertible and a 403 SW
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,330
    Quote Originally Posted by gromzx View Post
    Funny you should say that, but I've done the same thing to series 2 laguna's, clio's and a lot of scenics!
    2017 Renault Koleos auto
