306 S16 knock sensor
Results 1 to 11 of 11
    Apr 2005
    866
    Default 306 S16 knock sensor
    Whilst having a poke around looking at what I need to clean yesterday (while it's still in pieces), I discovered that the knock sensor on my S16 has basically disintegrated!
    I'm guessing at best it just isn't working, at worst it would be detecting pings that weren't there and retarding the ignition, or perhaps even putting the ECU in limp mode (doubt it as the car was running ok).
    Does anyone know the cost of one of these from Peugeot? I've found a few on Ebay for around 50 uk pounds with shipping, but I'm not sure if they are the correct one for the S16. If anyone has the actual peugeot part number for one of these that would be great! I'll see if I can see the part number on the sensor but it is in really bad shape!
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    1000+ Posts pgti6's Avatar
    May 2001
    1,618
    According to ServiceBox 2.0 litre Mi16 & S16 use part no-1920 K9.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Apr 2005
    866
    Thanks Jeff edit: when I google that part number it is coming up as a temperature sensor????
    Tony.
    Last edited by Wintermute; 7th April 2012 at 11:48 AM. Reason: googled but seems not a knock sensor.
    306 S16 1995 black
    May 2001
    1,618
    I just re-checked & I think it should be part no7.
    Attached Thumbnails Attached Thumbnails 306 S16 knock sensor-knock-sensor-s16.jpg
    Lap times-
    Sandown 1 27.9
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    Apr 2005
    866
    That looks more like it thanks Jeff. Do you need an account to access that site? Looks very handy!!
    The engine in that picture looks quite a bit different to mine as far as other paraphanalia connected to it. I've jot an XU10j4.
    Tony.
    edit: see that you have to register. Just wondering if they require a business name to do so. I'm thinking of putting in "other professional" as I it's the most correct I guess no harm in trying...
    306 S16 1995 black
    May 2001
    1,618
    You can register as a 'professional repairer' which gives you free access to the replacement parts section.
    Lap times-
    Sandown 1 27.9
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    NSW
    627
    I may have one lurking in the shed. Will look for you.
    We dont use them on race cars with programmable ecu's
    Adrian Wuillemin
    Apr 2005
    866
    Thanks Adrian!
    and Jeff I was wondering which option I should register under thanks for the tip
    Tony.
    306 S16 1995 black
    May 2001
    1,618
    I can't remember all the details from when I registered, but some kind person has written up the whole procedure here on the 306 forum-
    http://www.306gti6.com/forum/showthread.php?id=71768
    Lap times-
    Sandown 1 27.9
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    Apr 2005
    866
    Thanks I registered fine. Nice way to check for part numbers!!
    Tony.
    306 S16 1995 black
    Apr 2005
    866
    Default and why I need a new one!!
    I Thought I'd show a picture of why I need a new one of these.
    The connector is rotten as well. I pulled it off to get better access for replacing some of the rotten loom tube and when I went to put it back on (not that it was really necessary since I will be replacing it) the connector just fell to pieces!
    The oil pressure sensor is also looking like it has seen better days
    Tony.
    Attached Thumbnails Attached Thumbnails 306 S16 knock sensor-dsc_0614.jpg   306 S16 knock sensor-dsc_0618.jpg
    306 S16 1995 black
