How to remove 205 front seats?
    Dec 2010
    87
    Default How to remove 205 front seats?
    Hi
    I need to take out my front seats but cant get to the front bolts as the seat wont go back far enough.
    Is there a trick to this? I cant get a hex key in to loosen the bolt.
    cheers
    1000+ Posts djvu205's Avatar
    1,407
    cut/grind down the hex key so its very short. they will come out. also loosen all the other bolts and it may make the hard to get too ones, easier to undo. the reason there so tight is the the tilt mech was removed from the runners and the runners are bolted straight to the seat giving stuff all clearance, if its the car i think it is. lots of patience and good luck helps too.
    Dec 2010
    87
    hi
    its that that its tight but there isnt enough room to get a hex key onto the bolt. the seat frame prevents getting a key onto the bolt. can you get angled star hex keys? i have never seen them but that might work.
    cheers
    1,407
    hmmm not sure then? when they went in i used a ground down hex key. make sure the rails arent jamming. the hex key needs to be ground very short!
    Far North Queensland
    1,494
    Quote Originally Posted by fluery View Post
    Hi
    cheers
    Whilst a "hex key" might do the job , the correct tool is a torx T-40.
    There is are small cheap kits available which have a selection of smaller torx bits and a rachet driver.
    The bit/driver combination is more compact than a hex key.
    Something like this might be the go.
    http://www.ebay.com.au/itm/Offset-Ra...item231b568cf8
    or just a T-40 bit with spanner, using say a block of wood to hold the Torx bit into place.
    A Torx set comes in handy as 205s have lots of Torx headed screws and bolts in them.
    Cylinder head bolts are Torx and even the auto transmission drain plug is Torx.
    Paul
    “A straight is merely the distance between two corners.”
    Current: Peugeot 205 GTi Mi16 1987
    Peugeot 205 Si, one red one silver, both 1991.
    Peugeot 504 Wagon, V6 and 5 speed gearbox.
    Isuzu (Holden) Rodeo, 4WD dual cab, extended chassis.
    Past: Goliath, Isuzu Bellett, Austin A30, Peugeot 203, 403, 404, 504,505.
    Subaru 4WD wagon, Toyota Hilux Dual Cab Diesel 4WD.
