peugeot 205 gti seat replacement options
Results 1 to 20 of 20
    Fellow Frogger! james h's Avatar
    Jan 2005
    Barossa Valley
    168
    Default peugeot 205 gti seat replacement options
    Hello. I'm looking at replacing my drivers seat from the stock gti for something that dos'nt wear out and fall apart so easily.
    Do you guys have any recomendations or any links to say.. fit Mi16 seats or something from a japanese import in.
    Any step by step how to's would be great. cheers.
    205,405,505,306
    9,000
    If you require a step by step to replace a seat I would hazard a guess you should not attempt it.
    I don't now if Mi16 seats will fit, but I can tell you how to spruce up yours.
    If you take the fabric off and the foam is not crumbled to dust, you can glue back any piece that has broken and the seat will be like new.
    If you need to replace foam, you can use the foam (or the entire seat) off
    an Si or any other 205 you can lay hands on. Use the inner bolsters to replace your crumbled outer bolsters, glue them on (use contact adhesive generously), put the fabric back on, and voila! you've got a brand new pair of seats.
    ACHTUNG ALLES LOOKENPEEPERS
    9,261
    Quote Originally Posted by james h View Post
    405 seats no good as they are designed to be bolted to a slanting floor.
    They will be too flat in a 205, the front of the seat will be too low.
    205 Si seats are better than the GTi ones.
    Graham
    PDJ
    PDJ is offline
    Fellow Frogger! PDJ's Avatar
    Central Coast NSW
    204
    Lots of 205's with Mi16 seats in them. Very comfortable but there are a couple of issues. You will need to remove the door pockets as the seats are wide and with that you'll lose the window button holder. Also MI16 seats don't flip forward so you would have to register the car as a 2 seater. And lastly and with all non 205 seats they are made from dark matter so weigh more than 4 suns. Other options are 306 seats but again these weigh a tonne but arenít as wide so you can keep the door pockets. All options will need some fabrication to fit so your best bet would be to find a fabricator to fit which ever option you go for.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,439
    Default PDJ Right on!
    This fit was a trial and error process, lifted the seats in and out about 400 times and had to drill holes and make brackets etc.
    And NO I will not fit another set for anyone!
    Attached Thumbnails Attached Thumbnails peugeot 205 gti seat replacement options-dsc00086.jpg
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Feb 2011
    29
    Short answer: no, basically nothing other than Si seats will fit without modifications.
    Long answer: yes, after you chop, weld, grind, butcher, remove trim, and adjust 8 times.
    This topic comes up all the time. The narrow width of the 205 really narrows down your seating options so unless you are willing to do as stated above then you're better off with Si seats.
    I was in the same position, heeded the many recommendations for Si seats and found myself some low KM Si seats in great condition at the wreckers. Old seats out/new seats in = less than 1 hour. You can add me to the list of Si seat devotees.
    Fellow Frogger! jurgen_s's Avatar
    Belgium
    707
    in Holland I have seen 205's with
    405 mi16 seats
    Citroen XM seats
    309 GTI/16V
    306 GTI seats
    it is never a straight 1 on 1 fit, but if you are handy with a welder you can make anything work
    www.peugeotforum.be
    Belgium Peugeot Club
    Fellow Frogger! crims's Avatar
    adelaide
    130
    Familia gtr seats in mine
    1964 S2A LWB Landy Served in 1st ATF Vietnam
    1987 205 GTI Turbo
    2008 TE 510
    2012 Triton GLX 4x4
    2012 CX5 TT Diesel
    Fellow Frogger! le frogg 205's Avatar
    canberra city australia
    394
    celica seats in mine. you sit lower and have 3 way adjustables.
    cheers
    9,000
    That much about originality.
    One idea comes to mind.
    If 306 seats are the same width, perhaps the foam can be transplanted on the 205GTI frame? A pig of a job, but the result might be worth it.
    394
    would it be worth it to get new foam put on the seats so the problem hopefully wont occur again? just a though as i am getting a SI interior re-trimed for mine.
    cheers
    9,000
    Quote Originally Posted by le frogg 205 View Post
    cheers
    Absolutely, but where do you get new foam from? After market is not going to be the same, because the original is moulded to shape. Cutting new foam to shape is like trying to carve chewing gum, and just using square shaped foam is going to look horrible.
    adelaide
    130
    Have a look at the pics i put up in the resto section, they match pretty well, and are rock solid
    1987 205 GTI Turbo
    2008 TE 510
    2012 Triton GLX 4x4
    2012 CX5 TT Diesel
    brisbane
    2,899
    I have heaps of spare foam bolsters
    jr20516v
    Now:
    Exige SC [modded], 205 Si. 205 GTi , Megane R26 LY , Megane 225 [modded ]
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    9,000
    I think you used bits of foam cut from another seat. That is what I did too, and recommended above, but those are not new foam.
    Fellow Frogger! chile's Avatar
    Launceston
    155
    Schlitz, I think you need to do a bit more of the "Google everything. " part of your signature
    New thigh bolster
    http://205gticovers.com/Thighs.html
    New backrest bolster
    http://205gticovers.com/Squabs.html
    They are expensive but good quality.
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    Keep it original. Resto them for sure!
    Si's are they way to go.
    Then fabric them with flannelet....ohh sh#t yeah! comfiest GTi seats you'll ever sit in.
    9,000
    Quote Originally Posted by chile View Post
    New thigh bolster
    I have seen those, but I am not sure about the glueing bit. The area where they're supposed to glue on the bottom/back pad is very very thin/narrow. Not sure that would hold. The inner steel frame will help for sure.
    394
    ill give it a shot, ill buy them and make it the upholsterer's problem. ahahaha they look good, i hope their not made of the same foam the origionals are. :p
    cheers
    1000+ Posts Isis's Avatar
    1,100
    I went to a very big effort and put black 2003 WRX STI Momo semi-buckets in mine and the result is great. I had to completely take off all the seat mechanisms and weld on new mount plates. They are not adjustable but I dont plan to sell the car.
    Also, let me again say that the seat body mounts are flimsy and possibly cracked. lift the carpet and have a look. In a big accident the seats and you could rip out all together. I cant remember but I think the standard seat also holds the belt clip - this means that the pissy mounts are holding you and the seat to the car.... all ok until 205 and heavy things go bang.
    If you do what I did then you will likely need an engineers certificate and that is another process all by itself
    Ash
    S3 205 GTI x 4 and getting lower
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
