Peugeot 205 GTI Water Pump Problem
    Fellow Frogger! WhiteKnightGTI's Avatar
    Apr 2012
    148
    Icon1 Peugeot 205 GTI Water Pump Problem
    I recently bought a 1990 Pug GTI and the other day i noticed there was water dripping from behind the timing belt. I assume this is coming from the water pump, i need to fix it asap before it overheats and more problems develop, and i obviously cant touch it myself because of the tricky timing belt. A mechanic said it could cost around $800-1000. Can anyone confirm this problem or the quote price?
    9,002
    That's pretty much what you should expect. If you do the work yourself you can halve the cost and replace the belt and tensioner too if you don't have logbooks.
    These should be replaced anyway if you don't want to go there again for the belt change. Unless they were changed in the very recent past.
    ACHTUNG ALLES LOOKENPEEPERS
    7,483
    I will do it for $500! That's a rip off.
    1000+ Posts gezza's Avatar
    Bunbury
    2,191
    Just make sure its no the metal water pipe that runs opposite it, that corrodes and starts to leak..
    Apr 2012
    148
    ok thanks, ill have to get under it and have another look
    265
    Take off the top cover and make sure it isn't the welshplug
