306 Idler Pulley Noise
    Lismore
    133
    Default 306 Idler Pulley Noise
    Hi Fellow Puggers,
    I've got a horrible noise, mostly on start up, like a screech of a cockatoo. It's been suggested it is the Idler Pulley on the belt. Does anyone if the bearing can be replaced or is it a case of getn a whole new thing?
    I'm also after recommendations on who is best to get parts off. I need struts, lower control arm bushes and now maybe the idler pulley or bearing thereof.
    Any advice is gladly accepted,
    Keith
    Melbourne Australia
    1,382
    Screech or squeal can also be loose timing belt or alternator have you checked these ?
    Apr 2005
    866
    Or it can also be the main pully delaminating. That's happened on my S16 twice. Mine when it was doing it was worse when the air cond was on.
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    Lismore
    133
    Loose timing belt, mmm? Its due for belt. was done in June '9 at 152k - now done 230k - so is due. Must get it checked out.
    What about anyone with a idler pulley issue
    Dec 2005
    HOBART
    1,265
    Idler pulleys are an integral unit. I dont believe you can just replace a bearing. The cost saving isn't that much anyway
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
