205 GTI DFZ cam lobes and buckets
Results 1 to 17 of 17
    9,046
    Default 205 GTI DFZ cam lobes and buckets
    Pulling apart one of the DFZ heads I have, I found that the lobes on the cam are different. Some are pointy, some are round (no signs of obvious re-grind or wear). There is no rule, as in say exhaust-pointy/intake-round or the other way around. I will post some pictures.
    Two of the buckets show a different wear pattern too to the others, see pictures. Both these buckets are on pointy lobes.
    What is going on here? Why the different lobe profiles?
    What could have caused the different wear marks?
    ACHTUNG ALLES LOOKENPEEPERS
    9,046
    And here's some pictures.
    1. buckets showing different wear patterns. Left looks sus, came off a pointy cam lobe.
    2 and 3. Round cam lobe.
    4 and 5. pointy cam lobe, note the chamfered side missing at the tip of the lobe.
    Attached Thumbnails Attached Thumbnails 205 GTI DFZ cam lobes and buckets-buckets.jpg   205 GTI DFZ cam lobes and buckets-round-lobe.jpg   205 GTI DFZ cam lobes and buckets-round-lobe-2.jpg   205 GTI DFZ cam lobes and buckets-pointy-lobe.jpg   205 GTI DFZ cam lobes and buckets-pointy-lobe-2.jpg
    Perth Western Australia
    2,694
    Shlitz,
    The pointy [worn] cam lobe has lost its design feature of rotating the follower [left].
    But you knew that eh?
    9,046
    Thank you W'beest, it certainly looks that way, so you think that is wear that made the lobes pointy? Because it looks like very even, square and nice wear.
    You see, this is what I don't understand, were those pointy lobes like that from factory or not? It seems weird for Peugeot to grind a cam like that, but the cam doesn't look like it was reground or modified in any way (by some urchin) so I am a little confused here (quite a bit actually). And if that is wear as you say, then that is the most professional looking wear I have ever seen.
    And then there is the question of why did the pointy lobe not spin the follower (in the event that it is the correct factory grind).
    But that is unlikely. These lobes have definitely different profiles, and that is just not right.
    Anyway, looks like I need a regrind or new cam.
    2,694
    Schlitz,
    My mistake. I meant the worn cam lobe picture No 5.
    A cam in good condition will not show wear completely across the peak.
    9,046
    So this is wear? It's interesting if it is because it looks like instead of flattening the lobe has actually sharpened. Not impossible considering the strain on the lobe apparently is maximum around those areas that appear worn out on my lobes.
    7,487
    Your cam (and matching buckets) is worn beyond repair.
    9,046
    Hmm, I take it that's not good news.
    Is that the pointy lobes and the corresponding buckets or the other ones you are referring to, Peter?
    7,487
    Pointy ones. They should be fully radiused.
    9,046
    Any chance of a new cam and buckets from Peugeot (or any other source)?
    Can the unworn buckets be reused?
    Can the others be refaced?
    Can I regrind the cam?
    9,283
    I can send you a DFZ cam but you would probably be better off with a DKZ cam.
    I had an 8 valve cam (DFV, narrow lobe) with a worn lobe that was flatter , less pointy, than the good ones.
    Graham
    7,487
    2nd hand buckets can be sourced from a 2L 8V. They need to be dressed however. Fitting 2nd hand buckets to a new (or different) cam will result in lobe failure.
    9,046
    Thank you Peter. What do you mean by 2L 8V?
    And what is the dressing you speak of?
    7,487
    2 Litre, 8 valve XU10J2 as fitted to late 405, early Xantia etc.
    http://www.taylor-eng.com/16v_head/16v_head.htm
    9,046
    Another question.
    If I replace the camshaft will it fit straight in the head ? I know the head camshaft bearings are line bored so not sure if clearance allows camshaft swaps. My guess is yes, but would like confirmation.
    7,487
    Yes, it will drop straight in but you'll need to check valve clearances and adjust shims as required.
    9,283
    Default Head available
    Found the cam as promised, it is attached to a head, you can have the lot, cam head, buckets, valves etc. for $50
    Graham
