removing 306 ignition switch assembly
Results 1 to 2 of 2
    Sep 2011
    2
    Default removing 306 ignition switch assembly
    Howdy Folks,
    I'd appreciate any advice on how to remove the ignition switch assembly in my 1999 306.
    cheers,
    Nigel
    Jan 2011
    Traralgon
    648
    Generally, once the plastic shroud is removed and the battery disconnected, you will need to put the key in the ignition, turn it to the on position. There will probably be a small screw to remove from the underside of the barrel and may even be another spring clip to depress before using the key to pull the barrel out. The screw, spring and key are common features on most ignition barrels.
    Good luck.
    racing 405
    1:59:09 last time at Phillip Island - less than standard Mi16.
