505 XD2S Autopsy
Results 1 to 2 of 2
    Dec 2002
    Menzies Creek
    2,551
    Default 505 XD2S Autopsy
    After it's untimely demise a fortnight ago, I finally pulled the engine out of the 505 GTDTurbo wagon today.
    The car overheated (badly) climbing 'Tap Hill', a large, 14km stretch of uphill when you're heading north halfway between Gilgandra and Coonabarabran. There were 3 people on board, an 800kg hire trailer carrying a 403, which itself was full of spare parts. It was about 30degC outside.
    As expected, the head gasket has blown between 1 & 2.
    But the real surprise was the cause, or possibly causes.
    The first cause was that the fuse for the cooling fan was blown - which could only have been co-incidence. But I still couldn't work out why that would have caused such a problem, considering that we were still moving at 80kms/h when the temperature gauge started to soar.
    The answer came today once it was all apart. There is a hole, obviously a manufacturing defect, between the inlet and outlet of the water pump. About the size of a 10 cent piece, it meant that the water pump wasn't circulating water through the radiator, only around in circles within the water pump.
    It looks like it's been like that for a while, I'm surprised I hadn't seen any symptoms earlier!
    Tomorrrow I pick up the replacement engine for it. Hopefully it is as strong and reliable as this last motor was (up until last weekend)!
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Aug 2005
    Merimbula, NSW, Australia
    323
    At least the XD2S is easy enough to work on.
    Leon
    1987 Peugeot 505 GTD
    2010 Citroen C5 3.0 V6 HDi
