205 rear camber...issue?
Results 1 to 3 of 3
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    Default 205 rear camber...issue?
    I just noticed today that my drivers side rear, has noticeable negative camber.
    Where as the passenger side seems to have neutral to slight positive camber.
    Ride heights: Rear -30mm, front -30mm
    Is this bearings in one or both?
    Neither make any noise from what i can tell...
    Julian
    Melbourne Australia
    1,382
    If the camber is so obvious the beam needs a rebuild. Always better to do earlier rather than later in hope you may be able to reuse the shafts.
    Also read the other recent thread in Peugeot Forum on Rear Beam for a 205.
    Dec 2010
    canberra
    206
    i remember a post i made about 205 rear camber. it was on how to get it, not how to get rid of it.
    ahahah
    sounds bad, good luck with your beam.
    cheers
