Gday all
Man these things can be annoying considering they are old.
Fuel pump has suddenly stopped priming. I can't hear it anymore and the car is turning over and not starting.
I have checked all fuses and relays in the engine bay. I've even swapped over the relay behind the battery with no change. I've checked the pump itself with a multimeter and it isn't getting power. And putting 12 volts to it makes it work.
I'm dumbstruck. There is no inertia switch to reset as there isn't one for some reason.
What could this be? The ECU has shit itself?
