Changing the lower engine mount on a GTI6
Results 1 to 25 of 28
    Member HOT306's Avatar
    103
    Default Changing the lower engine mount on a GTI6
    G'day all.
    The lower engine mount on my gti6 project car has had it.
    I have a general idea of how to change it by removing the drive shaft etc.
    Just wondering about other people's experiences, for example, methods of changing the mount and types of mounts used. Rubber, solid etc.
    Any help would be appreciated. Going to attempt it in the garage.
    Cheers.
    Oct 2003
    624
    Driveshaft out.
    Undo the long bolt that clamps the bush to the subframe then undo the 3 or 4 13mm bolts off the back of the block.
    The mount is dowelled so you have to lever the mount away from the block before you can slide it out.
    Any type of solid bush, whether it be metal, nylon, nolathane or rubber, will create huge reverberation in the cabin. There is a significant increase in vibration and interior noise.
    If you want any resemblance of a quiet drive, fit an OE style bush.
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,428
    Ill agree with the above on the OE bush. If you want an annoying drive fit a harder one. Power gets the ground better via the softer OE one anyway especially in the wet.
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    266
    The bush can be pressed or cut out of the mount. Use the old one to press in the new one - make sure you get the angle right.
    Good luck getting the 35mm driveshaft end nut off. See Wintermute's gbox thread.
    Apr 2005
    866
    Yes they are incredibly tight!! BTW something I haven't posted on the gearbox removal thread is that the rattle gun (and possibly the 36mm socket instead of the 35mm) did do a small amount of damage to the nuts. There were some fine "iron filings" around the hub when I'd finished. mainly off the "skirt" of the nut not off the flats. I'll post a picture later on. Perhaps tomorrow.
    I was actually wondering if I should replace the lower mount whilst I have the drive shaft out myself!! It's been a while since I last had it replaced.
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    1000+ Posts pgti6's Avatar
    May 2001
    1,646
    I have a couple of spare ones I don't need. One has a std OEM bush pressed in only 6 months use, the other has an AutoFive solid rubber bush.
    $80 change over for your old one.
    405 Mi16 2.2 litre race car up for sale soon. For details contact me on 0438 106 430.
    Lap times- Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205 Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    7,536
    The easiest way to remove the mount is to carefully slit the outer steel ring with a hacksaw. Disregard rubber, inner etc. Then weld the ring back together with a few tacks on the inside. As the OD is now slightly smaller, it makes an ideal tool for pressing in/out the mounts.
    103
    Can anyone confirm whether the drive shaft end nut socket size is 35 or 36MM? Cheers!
    7,536
    35mm.
    103
    I seem to be only able to find a 1 3/8" socket which is 35.2MM and a 36MM, but no one seems to make a 35MM
    Sep 2003
    North Parramatta
    4,012
    Quote Originally Posted by HOT306 View Post
    1 3/8" is 34.92mm in my book.
    This thread sounds startlingly like the other Wintermute gearbox one
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    7,536
    ...........but no one seems to make a 35MM
    35mm. I don't have any trouble with this beastie. I should also point out that it's useless without another tool to stop the hub turning. It's mate attaches to the hub with two wheel bolts to stop rotation, whether tightening or loosening.
    Attached Thumbnails Attached Thumbnails Changing the lower engine mount on a GTI6-35mm-socket.jpg   Changing the lower engine mount on a GTI6-hub-nut-spanners.jpg
    Nov 2003
    Bondi
    3,428
    I removed them the other day with the car still on the ground, handbrake on. Loosened off fine. Was pretty tight though.
    91 205 Si
    87 205 GTi Race Car
    266
    This is fine if you have removable centres on your rims. Bit tough on a gti-6
    Apr 2005
    866
    Attached are pictures which demonstrate why you should use a 35MM socket and NOT a 36mm
    I got the 36mm because that was what size the PGTi6 forum thread on gearbox removal said the driveshaft nuts were. After Peter had let me know 35mm was the correct size, I also read another post on here by someone who had been using 36mm for years without any issue even though it wasn't the correct size so I thought I'd be ok.
    This damage is most likely caused by the looseness of the socket combined with the action of the rattle gun I used, but always get the right too for the job if you can
    I got mine undone with the wheel on the ground and handbrake on and a chock under the front wheel, BUT the S16 has removable centres on the wheels and I could get the socket on through there. If you do have to remove the wheels, then I think you will definitely need a tool like Peter's !!
    The damage is worse that I initially thought especially evident when photographed.
    Tony.
    Attached Thumbnails Attached Thumbnails Changing the lower engine mount on a GTI6-dsc_0544.jpg   Changing the lower engine mount on a GTI6-dsc_0545.jpg   Changing the lower engine mount on a GTI6-dsc_0546.jpg
    306 S16 1995 black
    7,536
    If you try to undo the nuts whilst putting your foot on the brake, you will most likely shear the two pairs of M6 CSK screws which retain the brake discs. And they still won't be loose.
    Dec 2010
    232
    Hot306 has an s16 too with removable rim centers.......
    Jul 2011
    Seaford Vic
    157
    Default rattle burrs
    well i had the same issue 36mm is wobbly so 35mm is ideal.
    clearly the advice you found at the forum was debatable.
    perhaps a 36mm hex-socket fits just not a 12 point socket?
    i hold the wheel with an axle or bar on the hub under two studs
    a bar that reaches to the ground stops the wheel from turning.
    garden hose slid on a length of reo-bar protects the stud threads or put the wheel-nuts back on the studs then put the bar across.
    the workshop manuals show a fork tool that fits onto the studs.
    266
    My lazy way that has never failed me is to remove the m6 countersunk screws that peter mentions and put in all the wheel nuts tight. Then you can use the brakes to hold the hub while you undo the nut with a f-long bar.
    Jul 2011
    Seaford Vic
    157
    well said and the hub-nut wrench needs a long bar for sure.
    i use the plain angle socket handle-bar with no swivel
    and i slide a one meter long piece of two-inch gal water-pipe on the end to extend the bar yonder.
    it soon does the trick to either loosen or tighten the blighters.
    a similar tool is the wooden tent-poles that come in half that are made with a metal tube on one end of the lower-half
    which is hollow for about 100mm and so fits on a socket handle-bar or fits a jack-handle also works on a big shifter or monkey wrench to make a temporary long handle.
    7,536
    Quote Originally Posted by Bobomacho View Post
    You must have very long arms like Mr Tickle.
    266
    Hide your kids and hide your wives.
    I should have mentioned its great to have a helper to press the brakes
    Or
    Make sure there is still plenty of vac in the booster and slide adjust the seat forward pressing a bar into the brake pedal does the job.
    Oct 2003
    624
    Or you can think outside the box.
    Don't undo the driveshaft nut, instead remove the brakes & abs sensor, undo the strut, lower balljoint and tie rod from the upright and remove with the driveshaft still attached.
    Apr 2005
    866
    Quote Originally Posted by tigr3 View Post
    The socket I bought was actually a hex one, not the 12 point in the image. I think the issue is the jolt that it gets each time the rattle gun engages. The rattle gun I got is not like any I've seen before, it only hits once every few seconds, quite possibly with more force than normal.
    anyway the main point was if you can get the correct size then do so If I'd known it was 35mm from the start I wouldn't have bought a 36mm
    Tony.
    306 S16 1995 black
    Jul 2011
    Seaford Vic
    157
    Default a touch too much
    for sure a good rattle gun is almost essential on these drive-shaft nuts and for trucks or four wheel drives.
    your photos make your point about the right-size memorable.
    i dread rattle-gun on the wheel-nuts when you get new tyres
    to loosen them with a measeley wheel-brace is the living end.
