306 Brake bleeding sequence??
Results 1 to 8 of 8
    Member JimP's Avatar
    May 2011
    Edmonton, Qld, Australia
    73
    Default 306 Brake bleeding sequence??
    Sorry to bother everyone, but I left home without my Haynes manual, and have to bleed the brakes (replacing the brake fluid) on my 1996 XTdt 306. No antilock anything.
    I know the manual gave a proper sequence, but I've forgotten it.
    Can anyone tell me what it is?
    Thanks in advance.
    19,211
    Quote Originally Posted by JimP View Post
    Thanks in advance.
    Start at the furthest wheel from the master cylinder and move progressively to the closest.
    You will need to check out the brake plumbing distances.
    In my experience it doesn't matter that much anyway, the wrong order just means a few more bleeding cycles.
    May 2011
    73
    Thanks Robmac,
    I'll give it a go!
    Regards.
    Sep 2003
    North Parramatta
    3,997
    The Haynes manual suggests that for non-ABS models:
    1. left hand rear
    2. right hand front
    3. right hand rear
    4. left hand front
    I would have suggested as robmac has, starting furthest from the master cylinder.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    May 2011
    73
    Thanks SLC206,
    I thought it suggested a funny sequence that I couldn't remember. Now I'll try to decide whether I'll go the logical furthest to closest route, or do what the manual says!
    Regards.
    Fellow Frogger! 908HDI's Avatar
    May 2011
    Gold Coast, Australia
    380
    Make sure to suck out as much of the old fluid out of the master cylinder container and replenish with fresh fluid prior to bleeding.
    I normally do the rear brakes first regardles of the car. You'll need at least 8 pumps for the fresh fluid to reach each of the rears.
    With ABS its a good idea to activate the system after bleeding. It should work at just above 10 kmh so a couple of activations on a quiet road will suffice.
    Clean and check all bleed nipples carefully after you finish.
    tweed heads
    1,497
    Default and also
    the rear suspension has to have weight on it to let the fluid through the compensating valve ,that cuts braking on the rear end as the back of the car rises PUGS
    265
    Quote Originally Posted by pugwash View Post
    Not an issue on 306's
    Gil
