505 Selector rod
Results 1 to 18 of 18
    Mar 2012
    australia geelong
    4
    Default 505 Selector rod
    My 505 has dropped one side of the selector rod from the gearbox to the gearstick. Appears the bush? in the cup has shredded and do you think i can locate either a refit kit or ven a second hand one. Looking for advise whether youve had this go and or does anyone have a parts one, cheers Rob
    Dec 2005
    HOBART
    1,265
    New rods are not expensive -around $25 from EAI or Carvelle. Alternatively,fill the cup with silicone and set it in place and let it cure overnight. It should last a year or two
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    Default EAI should have them.
    HEAD OFFICE MELBOURNE
    321 Middleborough Rd, Box Hill VIC 3128
    Ph: 03 9899 6683
    Fax: 03 9890 2856
    http://www.eai.net.au/contactus.html
    Change them all....Easy job.
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    651
    Quote Originally Posted by pugnut1 View Post
    New rods are not expensive -around $25 from EAI or Carvelle. Alternatively,fill the cup with silicome amd set it in place and let it cure overnight. it should last a year or two
    A couple of cable ties will also do the trick for around 5 years and counting.
    504 GL Coupe '73 Silver
    407 HDi Sedan '05
    1000+ Posts Beano's Avatar
    3,150
    Yeah, that'll work, but it'll be a bit of a loose gearchange if the bush has shredded.
    9,283
    Coat the ball with grease then fill the cup with Araldite and reassemble.
    Better just to buy a new one through.
    Graham
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,259
    A couple of layers of electrical tape and a bit of a trim with a sharp cutting device. As long as it's greased first and then becomes a firm push on fit it should get you out of trouble whilst awaiting the NEW PARTS!
    Coat the ball with a water resistant grease and "Happy trails".
    Mar 2012
    australia geelong
    4
    Default Thx Pugnut1
    Do you know if you can get the bush or replace the rod in its intirity, are the places you mentioned in Melbourne keen to be back on the road thx so much, Rob
    Dandenong Vic
    1,259
    The rods are a complete unit with the plastic bush in place. The worst part is that the nice/bright and shiny part makes the slightly grubby gearbox case look a wee tad 'ordainare'.
    So factor in a a couple of cans of de-greaser/hot soapy water and getting really dirty to give yourself the warm inner glow of a "Good owner".
    Dec 2005
    HOBART
    1,265
    I usually use a pair of multigrips or a long screwdriver to push the new rod on. They need a bit of a push.
    It would'nt hurt to spray some degreaser onto the gearbox and then wash it down before you try and fit it,
    Lots of good short-gap solutions. Good luck
    Gerry Mullock
    Mar 2012
    australia geelong
    4
    Default Where from
    Where would I get the selector rod, someone or somewhere who could almost get them off the shelf.? Im in Geelong and not one person here can give me a decisive answer outside of Rex Gorelle Peugoet who say they need to import from France...need my pug back on the road, cheers Rob
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by goaty2323 View Post
    The two businesses mentioned (EAI & Caravelle) will almost certainly be happy to mail you the offending item.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Mar 2011
    Linton.Victoria.
    1,239
    Hi-Should the afore mentioned guys be unable to supply then go to a bearing place such as C.B.C and get some new rod ends.I forget it the 505 shafts are threaded or not.It they are not go to a bolt supplier supplier & purchase a piece of threaded rod & a couple of nuts- to use as lock nut.It would be nice if the nylon bushes were replaceable!.Obviously you would need to take the old shaft with you.There used o be a good place up the top end of the major road that runs West & parallel to Geelong Rd.-Where the big Sphinks is.They sell tools ,bearings etc.
    Hope that assists.
    Peter.
    Lavers Hill
    317
    That place would be Blackwoods in 385 Thompson Rd Geelong. (the place on the road near the sphinx.)
    Also Rob Hamilton Bearings, Des Munday Engineering Supplies, Geelong Fasteners, and Geelong Industrial Supplies are all good places in Geelong to try for that sort of stuff.
    Also chat to Laurie Ogle Motors who has a bit to do with Peugeots - might have some ideas where to get parts locally.
    anywhere
    2,123
    EAI posts parts promptly. Order it in the morning and it should be delivered in 1-2 days. Any parts really urgently needed can be delivered by Priority Post, guaranteed next day delivery. It works, I get my tractor parts that way.
    Apr 2004
    Geelong
    168
    Grant Hore at Eurocity Motors might be able to help (he's an old Peck and Stokes boy) they are in Kelly Court off Thompson Road .
    Graham Lewis
    jervis bay nsw
    183
    a couple of cable ties work well, if you then wrap it with duct tape it is less sloppy and lasts a long time--is it a GTI or not?Be sure to specify as I think they are different-at least in the wagons, don't know about the sedans.-or maybe it's different between the wagons and sedans? Also there is another short rod( for reverse I think) whish is worth replacing at the same time. Max
    Mar 2012
    australia geelong
    4
    Thx People you have been most helpful cheers
