1994 405 SRDT air recirc prob.
Results 1 to 9 of 9
    Mar 2012
    17
    Default 1994 405 SRDT air recirc prob.
    Hi all, problem with my 405 air recirc button (electronic one) that in whatever position its pressed there is a constant electic motor humming noise from behind centre dash. Im guessing its a jammed motor which moves the recirc flap? Havent pulled it apart yet but is this a easy fix?
    regards Mark
    Gone Fishin' Haakon's Avatar
    May 2002
    canberra...
    8,751
    Common issue - motor strips its gears.
    Have one spare somewhere...
    Mar 2012
    17
    read below
    Last edited by 405srdt; 15th April 2012 at 04:57 PM. Reason: need to check part first
    Mar 2012
    17
    Cant get to it to remove as no room, and i dont want to pull out the whole dash.
    Where do you recon I can disconnect the motor from, just to isolate it as no need for recirc anyhows?
    Jul 2004
    896
    Yep common problem, and also with D8 model 406.
    Easiest thing is to pull plug off the motor/gearbox (little brown rectangle box about 70 -90mm long.)
    Next thing is to set the flapper that the unit drives to fresh air (as opposed to recirc).
    Decca
    Present --2016 2008 Outdoor / 2014 RAV4 Diesel (My utilitarian beast)
    Mar 2012
    17
    Worked like a charm, thanks for the tip Decca. Nice and quiet now!
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,332
    Any one got any advise on fixing it? Mine does it to.
    2017 Renault Koleos auto
    Jan 2006
    North West Tas
    46
    Hi,
    What I did was lift the bonnet and take out the pollen filter which resides underneath the plastic cover on the top right of the engine bay (passenger side) where you'll be left looking at the reciculation flap.
    I then manufactured a small piece of coat hanger or fencing wire into a prop to hold the flap open, (mine was closed causing the car to be fogged up most of the time).
    This has worked well for six years. Just remember to slide fan to slowest speed when following another smelly ol' diesel or car on a dusty road.
    Cheers.
    Mar 2012
    17
    Good idea that FB, it worked out sweet and set it to fresh, also even got to clean out a heap of old leaves, twigs, dirt and crap that I didnt even know was under there. Killed 2 birds with one stone.
    thanks for the tip.
