Manual conversion, 406
    Fellow Frogger! callipygous's Avatar
    Jan 2006
    Toowoomba
    797
    Default Manual conversion, 406
    Pondering getting a 406 coupe, but the problem is that most of them are automatic and the automatics are rubbish. If I were to pick one up that needed the transmission taken care of, what is required to convert it to a manual transmission?
    Peugeot 504 Intercooled T04 Turbo.
    19,211
    http://www.aussiefrogs.com/forum/sho...03#post1044403
    This may be a good starting point.
    Queensland , born a Croweater
    667
    Default to convert
    You really need a manual car cause you need the rad, the looms, the console, gauges, engine management, pedal brackets, clutch hydraulics, and then some as well as the engine box, stauchions and even one mount , all different, regards Fisher. You leave the body management so that impact management still talks to it. Thats about it, to start anyway. Merging the looms is real fun.
    Oct 2011
    Toowoomba
    650
    Default Might have a compliance issue...
    Quote Originally Posted by Fish View Post
    Merging the looms and not bollixing up compliance with ADRs reliant on performance of air bags and stability control would be a big problem- like one with the potential to void CTP insurance policy in a prang.
    Fellow Frogger! sfrawley's Avatar
    Feb 2001
    Goolwa SA
    339
    Wouldn't it be easier just to buy a manual coupe? There are five on Carsales at the moment.
    Stephen
    '03 P406 HDI
    '16 Renault Master
    667
    Default depends which loom
    The body manage ecu and collision units are separate from engine and trans , the loom merg only happened where the auto ecu and loom removed and the start wiring had to be rewired as did the wiring that concerend several engine sensors that were in the auto loom but had to be fitted into the manual engine loom, wasn't too bad. We had it all set up but no go, would spin and not fire up, we realised the engine ecu that was with the auto system was still there, swapped over and has never missed a beat. the airbag system initiates and goes out as normal, havent hit anything hard enough to see if it works yet, guess that disapoints a few souls. Definately an improvment on the auto box which wasnt up to the job.
