406 2.0 l manual-Instruments?????
Results 1 to 8 of 8
    Mar 2011
    Linton.Victoria.
    1,235
    Default 406 2.0 l manual-Instruments?????
    Hi-Any advice on above -Intermittent tacho,fuel gauge& speedo not working.
    Thanks,
    Pekay.
    Fellow Frogger! 908HDI's Avatar
    May 2011
    Gold Coast, Australia
    380
    It sounds like the instrument cluster has been out at some stage so most probably a loose rear connector or loose earth. You'll need to pull it out and check.
    Is there anything else affected ?
    Mar 2011
    Linton.Victoria.
    1,235
    No-Just those 3-temp. gauge o.k.. Will check out shortly.
    Thanks,
    Pekay.
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,865
    Try the resoldering the circuit board at the back of the cluster!
    2005 Renault Clio 182 Cup
    Mar 2011
    Linton.Victoria.
    1,235
    Pulled instrument panel out-someone has soldered a couple of extra wires on circuit board.Cannot find earth bolt to tighten as is mentioned on 'pommie site.Tried to remove the e.c.u. from behind glove box but could not get it to slide off the clip-apparently these plat up.Any clues?
    Thanks,
    Pekay.
    Mar 2011
    Linton.Victoria.
    1,235
    Default 406 instruments
    Hi-Wondering if everyone has 'gone to the moon' as all has gone so quiet on the above subject.
    Tacho worked a little better[sometimes] & the speedo did for a while also.
    Thanks if anyone can assist.
    Pekay.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,439
    Default Worth a try
    This suggestion may sound a bit dumb, though have you pulled out all the fuses and given them a good inspection a wriggle around and made sure that they are home properly in their places? My daughter's 2000 306 Xsi had similar problems and this cured them .
    Its worth a try.
    Good Luck.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Mar 2011
    Linton.Victoria.
    1,235
    O K 'Ralph'-I will be reasonable 'And do it your way'.Often the dumbest or simplest can be the answer.
    Best thing it won't cost anything but time[or a fuse.
    Pekay.
