A 504 Question
Results 1 to 20 of 20
Thread: A 504 Question
    1000+ Posts dogboy's Avatar
    melbourne,victoria,australia
    1,333
    Default A 504 Question
    Just wondering if all local (aust) cars had the 4 round h/lights?
    I like the look of the one piece h/light I have seen and presume to be Euro cars..
    If so can I change the headlight setup easily...and can the h/lights be bought here or do I have to shop o/s?
    Cheers & Thanks
    Rev. Dogboy
    1969 DS21 Pallas BVH with leather
    1970 Renault 16TS
    1967 Honda S800 cabrio
    Citroen 1970 DS21 Cabrio replica
    Citroen 1966 ID Safari (with 23 running gear)
    Citroen 1975 DS23 Safari
    1975 VW Kombi poptop
    1987 2CV
    Porsche Boxster S manual
    1988 Vespa PX200E
    anywhere
    2,014
    The 504 was introduced to Australia with the trapezoid lights and the injection had the kangarou light with inbuilt driving lamps. The twin headlights were introduced in 1973 with cheap low quality Australian made lamps.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,441
    Default Throwing some more light on this
    [QUOTE=Russell Hall;1043876]The 1800cc 504 was introduced to Australia with the trapezoid lights and the injection had the kangaroo light with inbuilt driving lamps. The twin headlights were introduced in 2000cc 1973 with (cheap low quality?) Australian made Lucas lamps. My 1973 Ti had Lucas 85watt Halogen sealed high beam units from new?
    Can anybody confirm this?
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Fellow Frogger! sfrawley's Avatar
    Feb 2001
    Goolwa SA
    339
    Quote Originally Posted by Russell Hall View Post
    My "cheap, low quality" low beams have lasted the life of the car! The high beams would probably have done the same but I changed them for 100w Hella halogens about twenty years ago.
    Stephen
    '03 P406 HDI
    '16 Renault Master
    SWOTR
    3,634
    So far as I know, we went to the four round headlights to help comply with Australian local content requirements so I'm not sure that "cheapness" had anything to do wth it.
    1000+ Posts Beano's Avatar
    3,149
    I used to like the round headlights. They threw out a nice wide beam. And they're cheap to replace if they get broken. The trapezoidal ones are hard to come by ( these days) and expensive to replace.
    My advice would be to keep the round ones.
    You can upgrade the high beam round lights to some pretty bright ones ( equivalent to Cessna landing lights, actually), but be aware if you're doing 100 Ks on a country road with really bright high beams, and have to dip your lights, sometimes you momentarily can't see where you're going.
    When I had trapezoidal lights I always wanted round ones like on my previous car !
    anywhere
    2,014
    The early 2 litre cars also had trapezoids. I believe that local content was a factor but cheapness was the main motivation. They were a great disappointment compared to the trapezoids. I don't know what the injections were fitted with.
    Jul 2003
    bundaberg
    343
    Default 504 Headlights
    One of our 504's had twin headlights with Cibies for both high and low beam. They were brilliant. Even old Holden HZ's had Hella twin lights and these were also an easy and cheap fit to the twin headlight setup. Those were the days when one could go to a wreckers and find a set of twin lights in almost any car, my Cibies I found in a Dato 1600 and only paid $10 for them about ten years ago.
    You may even be able to find well priced new ones at an Off Road place eg. IPF or Hella are often in stock. Look for semi sealed so you have greater choice of bulbs.
    Geoff.
    Dec 2002
    Menzies Creek
    2,541
    If you want impressive headlights on a 504 it's hard to go past a Q4631 sealed beam or two, 13V, 250W, perfect beam spread. Just make sure your wiring is thick and you have a strong alternator and heavy duty relays for each filament (at least 25 amp). It's better than driving in daylight!
    Beam Spread - Horizontal 13° - 10 %, Beam Spread - Vertical 12° - 10 %, Max. Beam Candlepower (MBCP) (MAX) 85000
    Incidentally, if anyone has a spare set of Kangarou's lying around, I'm in the market!
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    350
    I have the trapazoid biodes [built in driving light] and they are still up there with modern lights. They are, however, very scarce and expensive and you need a few fidly bits of plastic,springs etc. to fit them. They look good but good inserts in both the high and low beam of the round ones are as good and much cheaper as mentioned above. Neil
    Dec 2002
    Menzies Creek
    2,541
    Quote Originally Posted by neil s View Post
    My '83 wagon had a set in them too, and I didn't think to swap them out before it went on eBay to Africa. Bugger!
    Scotty
    1,333
    I'm not too concerned with the lights effeciancy as it will be a club car & not driven every day..
    I think the trapezoid light looks the best and I hope to get a set to fit to my 504..
    anyone out there got a couple?
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
    9,261
    The injections had 75 w sealed beams.
    When the twin headlight models came out I stopped lusting after new 504s, the trapezoidal lights were part of the styling just as the painted headlight rims were on the 404.
    Graham
    Sep 2004
    Tamworth UK
    624
    Can probably find a pair of good ones (traps) pretty easily over here in NZ for you.
    anywhere
    2,014
    A word of warning about trapezoids. The fixing glue for the lens isn't up to the task. After a few years the lens falls out and you run over it. Had it happen to mine.An added hazard for teachers is if you're working at scumbag college the lamps are a tempting target and easy to kick in (happened to mine).
    Lilydale, Melbourne
    2,095
    Graham
    at Graham lusting after 504s!!
    My 1979 504 has Hella H4 round headlights, four highbeams. They are excellent. I have a set of Chinese trapezoidals for the TI, just for the look. I don't expect them to be particularly good.
    John W
    1974 Peugeot 504 TI
    - now on the road
    anywhere
    2,014
    Ryans in Elizabeth St were Cibie agents and I bought a couple of biodes there.
    1973 was not only the year of the four headlights but when Renault put a rocket under 504 prices. In October 1972 I bought a new 504 with French seats for $4150 on road. Went to buy another in August 1973 and the price was close to $6000. Didn't take much to get a $600 discount. But what an increase. I never thought the 1973 car to be the equal of the earlier one.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    547
    I have a pair of trapezoids in the rally car for the look, and have fitted an HID kit to them for the light out put.
    Its the best of both worlds.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Fellow Frogger! julian b's Avatar
    Aug 2011
    hawthorn melbourne
    482
    In aus the round lights were fitted for local content and cost reasons ,in the USA all cars sold there had to have sealed beam lights that could be replaced from any service station . They came in round or square . They ruined the look of many euopean cars ,like citroen Ds and Sm which couldn,t have swivelling lights or perspex covers . Clessics with Euro lights in Us are sought after now
    1,333
    If anyone comes up with a good pair I'd be grateful....
    even across the ditch !!
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
