Was a rough idle... 306 gti6
    Fellow Frogger! BradlehGordz's Avatar
    Sep 2011
    398
    Default Was a rough idle... 306 gti6
    This morning it stalled 4 times trying to start it and i thought it was because it was cold, and it ran find after that... and all today, but when i got in it to go home, the revs were f*cked! On idle it was reving to 3k and dropping to 1.5 and going back up when ever it was idleing or when i dipped the clutch.... anyway, I just disconnected the ecu then and it is a lot better, I don't know if it was a coincidence, but it only rises about 100 rpm and drops, so does this sound like a ICV problem?
    Also, would this cause the stop light to illuminate?
    P-Plater
    Obsession for le Peugeot!
    Current:
    '98 306GTi6 + Bianca white+ Sun roof.
    Previous:
    '99 306Style
    I live for the 6!
    Fellow Frogger! Karoshi's Avatar
    Feb 2011
    268
    No stop light for icv.
    I might be wrong but your symptom of running high then low is more likely an air leak in the intake assembly?
    I just changed my stepper motor in the icv and think I have solved my intermittent idle problem after a few years of it touch wood. I had the icv cleaned when it started but i didnt realize the stepper was a seperate issue.
    Mine used to just die at idle at random times. By die I mean stop....
    Good luck,
    Bill
    Sep 2011
    398
    If it was a leak, theoretically the ECU restart wouldn't have done anything?
    What hoses in particular would I be looking at?
    P-Plater
    Current:
    Previous:
    '99 306Style
    I live for the 6!
    Feb 2011
    268
    Any cracks in the intake piping may mean air is not proportioned correctly between main inlet and icv OR air leaks in inlet manifold gasket means incorrect air fuel ration (air introduced after the injectors).
    I'm no expert so I'm fully expecting to have someone correct me
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,428
    This woldnt have anything t do with your car overheating over the last few days etc?
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Sep 2011
    398
    The overheating was due to the coolant not being bleed correctly, kind of embarrasing :L haha
    This is only happened within a day or two, just came out of no where?
    It had a little idle problem before, but I cleaned the ICV and it was cleaner after that, but when I cleaned it this time it didn't work? Until I didn't an ECU reset after putting it back in (I heard you have to reset your ECU after you clean or put a new ICV in?) correct me if I am wrong?
    P-Plater
    Current:
    Previous:
    '99 306Style
    I live for the 6!
