306 ECU reset procedure - is this correct?
Results 1 to 14 of 14
    May 2004
    Melbourne, Australia
    228
    Default 306 ECU reset procedure - is this correct?
    For an N3 306 XU7JP 1.8 with the Bosch ECU, is this the correct reset procedure?
    - disconnect battery for 10 minutes
    - reconnect battery
    - turn key to 'on' position and wait 10 seconds
    - start car
    - turn fan to max, lights on, a/c on. (for maximum alternator & engine load.)
    - allow to idle until warm and fans cut in
    - take for a drive
    spiz
    Fellow Frogger! 908HDI's Avatar
    May 2011
    Gold Coast, Australia
    380
    1] Disconnect battery for 20 minutes
    2] Reconnect Battery
    3] Turn on the Ignition
    4] Turn off the Ignition
    5] Start Engine then switch off
    6] Close the doors and lock the car with remote
    7] Unlock car with remote and start the engine
    8] Open Glove Box
    9] Pull down drivers Sun visor
    10] Push in cigar lighter
    11] Switch on radio
    12] Open Boot
    13] Walk around car three times
    14] Press horn twice
    15] Open Bonnet
    16] Flash the lights five times
    17] Pull handbrake
    18] Connect rear seatbelt to front drivers seat
    19] Remove passanger headrest
    Only kidding ! 1-7 should work.
    Fellow Frogger! Molerpa's Avatar
    Jul 2005
    South America, Argentina, That country that looks like hanging from the map... just about to fall...
    492
    20- open the boot
    21- remove the weed...
    22- have a cold shower
    Quote Originally Posted by luthier View Post
    It is simply impractical to expect a petrol motor to get through too much water. That's why God invented diesels.
    Jun 2011
    Tasmania, Australia
    215
    Quote Originally Posted by Molerpa View Post
    20- open the boot
    23- Finally a six pak of VB is highly recommended ! while pondering which Toyota model to purchase
    Alain
    Jun 2011
    Tasmania, Australia
    215
    Seriously
    The 306 1.8 8valve (XU7JP) is fitted with the Magneti Marelli 8P self learning type ECU.
    When the battery is disconnected the ECU reverts back to preprogrammed base settings and the optimum settings "learnt"are lost.
    When battery reconnected the engine may run a little flat for a while untill the ECU "relearns"the optimum settings.
    This is best achieved by taking for a 15min. run varying eng. speeds and loads concentrating in the 2500-3500 rpm range and after a while will be tuned to the condition of the input sensors etc.
    Forget all the other BS that applys to multiplexed (later) systems.
    Therefore if you want your 306 running perfectly replace the sensors .The cost will be outweighed by better fuel economy, power and driver enjoyment.
    Alain
    San Diego, California, USA
    3,541
    Quote Originally Posted by 908HDI View Post
    8] Open Glove Box
    11] Switch on radio
    12] Open Boot
    15] Open Bonnet
    17] Pull handbrake
    I simply swing a live, shaved ocelot overhead while incanting "Klaatu, Barada, Nicto!" It helps to have a funny hat. And Bactine. Lots and lots of Bactine.
    This works for the GM injection systems in streetrods, and I have the scars to prove it.....
    Jul 2005
    492
    You're totally right.
    In fact, I think the Hakka was inspired on the ECU reset procedure.
    Quote Originally Posted by Alain View Post
    Seriously
    I could understand that you are trying to say that we were not serious... which I disagree
    Alain
    absolutely right.
    Member Ginch's Avatar
    Feb 2012
    Ballarat VIC
    44
    So there are no multiplexed 306's?
    And if I want to acheive the best fuel economy from a car which is just new to me, is it worth doing a reset? Or replacing the sensors... sounds expensive.
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,329
    whats actually wrong with it?
    2017 Renault Koleos auto
    May 2004
    228
    Quote Originally Posted by cav91 View Post
    The idle is erratic, sometimes high( 2500rpm!), sometimes perfect.
    David suggested trying an ECU reset first before replacing what I think could be a faulty MAP sensor.
    (The stepper motor/idle control valve is new.)
    spiz
    Jul 2005
    492
    what about a diagnose, before starts changing parts, until finding which was? (after the entire car replacement)
    May 2004
    228
    Quote Originally Posted by Spiz View Post
    The erratic high idle was caused by a faulty coolant temperature sensor. (the green one.)
    Caused the mixture to be rich and hence a high idle and a blackened oxygen sensor.
    Occasionally the dash ECU light would illuminate when stopped, then go off when moving again.
    (Fault code was #31,"Mixture regulation auto-adaptation")
    spiz
    Don't remind me!
    16,609
    That's quite unusual.
    Was the failure a result of internal leakage, external stress, or were there no signs of change to the sensor?
    I like to watch the parameters from a cold start, to see injector times shorten and the coolant temperature to rise.
    May 2004
    228
    The sensor looked ok, and measured ok too (when cold). I am guessing that when hot it was going resistive.
    A common problem in the uk, which is what gave me the idea.
