Putty around oil filler?
Results 1 to 11 of 11
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    I changed the oil in my 505 GR today, and noticed that there was small amounts of a cream/orange coloured sludge in the gauze filter and also in the dipstick tube. The old oil itself looked pretty clean. Is this the infamous 'mayonaise' sign of a blowing head gasket? It looked like the putty you use to fill gaps in wood.
    Nick
    1983 Peugeot 505 GR
    Banned
    Mar 2003
    179
    It may well be. Could also be just emulsion (oil water mix) that doesn't get "zapped" because the engine never gets really warm. Does the car go on long trips to get everything up to temp? Is there "mayonaise under the oil filler cap?
    Fellow Frogger! AlsPug504's Avatar
    310
    Could be head gasket or cylinder liner gasket. Whats the water in the radiator like creamy throthy not good! spanner
    Al
    <small>[ 02 July 2003, 08:03 PM: Message edited by: AlsPug504 ]</small>
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Nick,
    I wouldn't lose a real lot of sleep over it at this stage as it sounds like mayonnaise something commonly found in Cits & Pugs overseas.
    In the 405/BX series over there it was so common that Pug repairers used to allow for a new dip stick & tube every so many ks as it had the tendency to blow the dipstick clean out of the block.
    Apart from cleaning out the breather system & doing regular filter & oil changes in the colder weather, it was also found that often this was also a sign of a faulty thermostat.
    I know yours has a much different system to the 405 but the same principles apply, so clearing it all out of the breathing system and a new thermostat, not an expensive item, could help reduce the problem. If allowed to get really bad, it can create problems, after all, mayonnaise is water mixed with the oil so not the best mix of lubricants known to man.
    Alan S
    Member Pugknut's Avatar
    Oct 2002
    Melbourne, Victoria.
    90
    I tend to agree with Peabody. The old 404 was fine in the summer, but in the cold weather with a little more moisture in the air the mayonaise would appear due to condensation, especially with short tripping. I would not do anything drastic at this stage, but keep an eye on it shy . Other good head gasket tests include running the engine with the radiator cap off (from cold of course) to see if there are lots of bubbles being blown in the coolant.
    9,223
    Leave the oil cap off for a hot run... let the moisture that evaporates expel itself from the engine...
    Banned
    Mar 2003
    179
    Should be no need to leave the cap off if the PCV is working.
    8,923
    Should stop everything rusting under the bonnet if she's got a bit of blow by though.
    The thermostat trick we worked out on the overseas boards. They give a thermostat about a 3 year life expectancy over there. I was starting to get it in my 16V & it (new thermostat) cured it. Instead of taking about 20 miles to get near operating temperature, it's closer to 2, hence you don't get the condensation that is there with a half stuffed thermostat.
    Alan S
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    The car has been doing heaps of short trips, and I've also discovered a large crack in a pipe in the PCV system - the rubber hose that runs from around the manifold (?)/left side of carby to the oil filler.
    I took the pug on a 3.5 hour drive up to Chilton and after checking the oil the 'mayo' seems to have disappered.
    Also, for as long as I can remember the dip stick seems to have popped a few cm out of the tube everytime I drive the car. Why does it do this?
    <small>[ 04 July 2003, 06:24 PM: Message edited by: nJm ]</small>
    Nick
    1983 Peugeot 505 GR
    9,223
    Blocked PCV valve or excessive blow-by... maybe that's why the hose is split too?
    Banned
    Mar 2003
    179
    You've got it.
