XU9/XU10 rod bearings
    7,483
    Default XU9/XU10 rod bearings
    I've been researching rod bearings. Found some info you may find useful. As you know, copper/lead bearings for Mi16's are hard to come by. However, it turns out that ACL have a few options. They make a bearing for the 405 turbo diesel in F780 (copper/lead) in std, -0.3, -0.5 and -0.8 undersize. The catch is the tang is in the wrong spot. Easily fixed when reco'ing the rods however.
    They also make std rod bearings for XU9/XU10's in F810 in std, -0.3 and -0.5.
    They also make a "race bearing", same material as diesel, F780, in the normal XU9 petrol configuration, but it's only currently available in std and -0.25. I suggested they add -0.5mm to their range. There is a possibility if they get enough demand. I've thrown away plenty of Mi16 cranks that could otherwise been saved if there was -0.5mm. So speak up! Contact your local ACL rep asap!
    turbo diesel - 4B1685
    standard petrol - 4B7702A
    race bearing - 4B7700H
    Do a search on their website for full specs.
    9,261
    Never seen ACL bearings for these engines, wonder how many they sell?
    I would buy a couple of sets even though I suspect the bearings are Honda in the XU7 I just bought, who knows how long even the standard material bearings will be available for?
    Anyone else?
    1000+ Posts pgti6's Avatar
    May 2001
    1,618
    Crankies fitted copper/lead big end bearings to my (0.3mm undersize) crank from a 2.0 litre Alfa. They needed to machine a new groove for the tang as well.
    Don't know whose bearing it was though.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    7,483
    Miles from 205 Forum uses them, so plenty in the UK.
