306 rear swing arm bearings
    Member JimP's Avatar
    May 2011
    Edmonton, Qld, Australia
    73
    Default 306 rear swing arm bearings
    I have to replace the front shock absorbers (struts) in my 1996 306 XTdt, and am thinking of also replacing the rears.
    Lewin from Peugeotspares in Brisbane suggested also replacing the rear swing arm bearings. He said that if the rear wheels are leaning in at the top it indicates that the bearings need replacement. My rear wheels do lean in a little at the top.
    Has anyone had any experience with this job? How hard is it, and are there any how-to's available anywhere? The Haynes manual is completely silent on the subject.
    Thanks.
    Dec 2010
    232
    Pulling out the rear arms is one of those easy but hard to do jobs !
    A few how to's around the net if you search...
    Goodluck with it
    Far North Queensland
    1,494
    Default Rear Beam Refurbishment Guide
    Here is a guide from GTi Drivers Forum
    http://www.205gtidrivers.com/article...rearbeamrefurb
    Was some discussion on Aussie Frogs too a while back but that might have been lost.
    Paul
    A straight is merely the distance between two corners.
    Current: Peugeot 205 GTi Mi16 1987
    Peugeot 205 Si, one red one silver, both 1991.
    Peugeot 504 Wagon, V6 and 5 speed gearbox.
    Isuzu (Holden) Rodeo, 4WD dual cab, extended chassis.
    Past: Goliath, Isuzu Bellett, Austin A30, Peugeot 203, 403, 404, 504,505.
    Subaru 4WD wagon, Toyota Hilux Dual Cab Diesel 4WD.
    May 2011
    73
    Thanks to both of you for your responses. It looks like more of a job than I would care to take on unless I really, really, had to. I'll just try changing the shockies first and see where we go after that!
