headlights on again - off again
    Jan 2012
    Perth WA
    32
    Default headlights on again - off again
    Hi all
    Have just become the lucky owner of a 504 Wagon, and first question as a new owner is concerning the headlights which seem to turn on sometimes and not others.
    Is there a secondary switch somewhere or should I be looking for loose connection in the wiring or relays?
    22
    Hi
    It's best to check all connections from headlight switch and then follow through to the relays of which there may be two one under the instrument panel and a second on the inner guard. I would also be checking that the earth's are clean and tight
    Jan 2012
    Perth WA
    32
    Thanks Chris, will folllow through all the wiring tomorrow with the light of day.
    It's how I roll...Brisbane
    33,447
    You will be looking for a bad or dirty earth at the light fitting as well.
    12,269
    you have a tow bar ??
    if so i'd be checking the connections there as well
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
