405 idle
Thread: 405 idle
    Dec 2010
    Mangonui NZ
    82
    Default 405 idle
    Hi folks. our 1993, 250,000Km 405 STi A has gone idle mad!!..........been through suggestions in manual but cannot stop it idling v fast. Any suggestions??
    Thanks. Dave
    8,426
    Quote Originally Posted by Far North Kiwi View Post
    Thanks. Dave
    Find and eliminate the air leak.
    Jo
    Oct 2011
    Toowoomba
    650
    Default 405 idle
    Jo
    Might also be a sticky idle speed stepper motor (look for a motarolla labled black thing on the throttle body)
    tweed heads
    1,497
    Default Not sure about sti
    But my mi had a sender on the thermistat housing which when removed coused a high idle,an open circuit on this sender tells the ecu that the motor is cold and the mixture shoald be richened and idle speed increased [choke function]it tends to produce some strange results if the fault is intermittent check that the wire is attached to the sender .check for air leaks especialy the plastic boot that attaches the air cleaner to the throttle body ,they crack .pugs
