It's here
Results 1 to 13 of 13
Thread: It's here
    12,266
    Default It's here
    the back to front 604 wagon turned up last night (406stdt)
    big thanks to dave at french connection
    now the fun begins
    now i don't know if this has anything to do with the alternator not working at the moment but when you go to turn the headlights on nothing happens but if you pull the stalk back they flash
    will be checking fuses and the like this afternoon but i thought that was a little strange
    engine check light is on but that may also be something to do with the non charging situation so will see what happens when i get to that
    will be doing a timing belt, water pump, idler, tensioner and accessory belt job on it very shortly so that will be piece of mind in that department but while the front end is apart the alternator will be coming out and getting rectified
    now i have tried to no avail to download or find to download a user manual for the car (i just like to have one with each car) but none can be had unless you speak russian or spanish
    if someone has one and doesn't want it anymore talk to me, thank you
    i asked the truck driver if he wanted to also drop the car off that was in front of the wagon to save him stopping again but he said he better not
    it was a red mid 70's 911, would have looked nice IF i could have found somewhere to park the car in the yard
    i don't know what the neighbours thought last night seeing yet another car arrive this time on the back of a semi
    pics will be up soon and other pics of work as i get to it
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    16,490
    A 406 is just a spec'd down Xantia isn't it Given this the first port of call is probably the ignition switch itself. The contacts in it burn as they didn't relay the interior fans. Check the big fuses under the bonnet.
    You could also whip the battery out and check under that. What poogoe did was put all of the earth points in a common position.... They picked the "best" spot they could think of. That being underneath the battery where battery acid could get to them
    Surely we could have found you something decent like a nice CX wagon :poke:
    Dec 2010
    Bungendore NSW
    498
    Such rude words from someone who drives a pump-up Peugeot
    Oct 2003
    canberra
    857
    Default 406
    I have a new D8 ignition switch for sale Shane if you need it
    16,490
    Quote Originally Posted by Flash Car 76 View Post
    You gotta stir up 'Rambo, he'd think something was wrong if we didn't
    16,490
    Quote Originally Posted by alpine View Post
    It maybe 'Rambo that needs one ... we'll see
    Melbourne Australia
    1,382
    [QUOTE] now i don't know if this has anything to do with the alternator not working at the moment but when you go to turn the headlights on nothing happens but if you pull the stalk back they flash [QUOTE]
    Maybe it's crafty Peugeot engineering design for saving the battery when driving at night in stop / start traffic : )
    London, UK
    294
    Peugeot 406 Petrol and Diesel (96 - Mar 99) N to T
    Saloon and Estate, including special/limited editions, 96 - Mar 99, N to T
    Petrol: 1.6 litre (1580cc), 1.8 litre (1761cc) and 2.0 litre (1998cc) 4-cylinder normally-aspirated
    Turbo-Diesel: 1.9 litre (1905cc) and 2.1 litre (2088cc)
    Does NOT cover Coupe
    Does NOT cover 2.0 litre Turbo or 3.0 litre V6 engines
    Does NOT cover 2.0 litre HDi Turbo-Diesel engine
    I have one of these brand new that I don't want/need:-
    Peugeot 406 Petrol and Diesel (Mar 99 - 02) T-52 reg.
    Petrol: 1.8 litre (1749 and 1761cc) and 2.0 litre (1997cc) 4-cyl
    Turbo-Diesel: 2.0 litre (1997cc) and 2.2 litre (2179cc)
    Does NOT cover 2.0 litre Turbo, 2.0 litre direct injection (HPi), 2.2 litre (4-cyl) or 3.0 litre (V6) engines
    Feb 2001
    Romsey, Victoria, Australia
    4,869
    [QUOTE=Andrew Ch;1035773][QUOTE] now i don't know if this has anything to do with the alternator not working at the moment but when you go to turn the headlights on nothing happens but if you pull the stalk back they flash [QUOTE]
    I must admit we never tried the lights, never used it at night and tried to preserve as much battery as possible.
    Sounds to me like the switch has failed. If they work on flash sounds like the car is fine but just not switching on.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Oct 2011
    Toowoomba
    650
    Default Fusibles a la mort...
    The original euro fuses in S2 405 have a tendency to get fatigue cracks at the ends of the fusable link. The fuses look OK, test OK when out of the fuse panel but go open circuit when pushed in. Worth replacing every fuse you can find with new ones (Try Ashdown or Radio spares)
    Also there are various headlight relays tucked away in various places (above drivers' right knee in 405) as well as the realays in the box next to the battery. The flash circuit seems to have its' own relay while the dash mounted relays work in the poverty spec cars with 40/45W headlights and the halogen light cars have the extra relays added, but the originals remain. Some 504s (73, 74) have a high beam relay like a late 404 behind the instrument panel and the duplex relay on the inner mudgaurd.
    I'm probably being mean, but try looking for a little flouro green or bright orange relay with "Gadgets Cartier" on it...
    Bruce.
    12,266
    [QUOTE=David Cavanagh;1035996][QUOTE=Andrew Ch;1035773][QUOTE] now i don't know if this has anything to do with the alternator not working at the moment but when you go to turn the headlights on nothing happens but if you pull the stalk back they flash
    that's my thinking
    got any there David ??
    also note to myself, same switch as my 605
    1 x 2018 3008
    12,266
    [QUOTE=Bruce Llewellyn;1036004][QUOTE=Andrew Ch;1035773]
    Bruce.
    tried looking, found some relays, still no luck
    will try with a switch and if still no good off to a sparky it will go
    1 x 2018 3008
    London, UK
    294
    here is the wiring for a UK spec 406 D9
    there are no relays, it's just a power feed to the switch, through a couple of fuses and onto the headlight unit
    If I had one I think I would add a couple of relays (one for dipped, one for main) and use the switch to trigger the relay instead of powering the bulbs directly
    406d9 headlamp circuit by dieselnutjob, on Flickr
