SRDT 405 Battery Dash Light
Results 1 to 7 of 7
    Apr 2004
    Western Australia
    237
    Default SRDT 405 Battery Dash Light
    Hello , someone may be able to help me. The small battery dashlight in my 1994 405 SRDT has come on and doesnt go off it dims a little but stays on. Am I correct in assuming it means the alternator is stuffed or could it be something else????
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,330
    Chheck the alternator charge rate.
    2017 Renault Koleos auto
    Apr 2004
    Western Australia
    237
    Thanks for that it seems to be charging at about 11 volts tops
    19,211
    Quote Originally Posted by glenough View Post
    Field diode in the alternator has probably failed...
    Sydney, Australia
    308
    It sounds to me like the brushes have worn. ie: The alternator is still good but the brushes aren't making good contact.
    Garth.
    Fixin' Cit's.
    '19 308 GTi
    '15 DS 5
    '74 GS Convertisseur
    In the family
    '51 Traction
    '08 C5 X7 V6
    Previous ownership
    '95 XM V6 Series 2
    '96 306 XTDT
    Romsey, VIC
    2,330
    11 volts means dead alternator. I'd try find a good second hand one.
    Oct 2011
    Morayfield, QLD, Australia
    108
    Default Possible faults
    The manual says that there is faulty operation of the charging circuit. Loose battery or starter terminals, A broken or slack alternator belt or a bad alternator. I'll add that the wires connected to the alternator have to be clean and tight. If all your connections are clean and tight to the starter/alternator/battery, then its a faulty alternator. Also, the alternator usually charges between 13 and 14 volts when its working well. I hope this helps!!
    lamlam
