205 GTI question
Results 1 to 7 of 7
    9,008
    Default 205 GTI question
    Hi dear brains' trust.
    I have a little problem in this heat.
    Sometimes after shutting the engine off (engine at normal temperature) and leaving the car for a little while (not enough to cool the engine), when I try to start it needs a bit of cranking (when cold fires literally straight up). Same problem happens on hot days if I leave the car in the sun and then try to start it form cold (which is not cold though in this heat; I have had the temp gauge go up two lines on the dash with a "cold" engine).
    What does the brains' trust think?
    ACHTUNG ALLES LOOKENPEEPERS
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    919
    I'm not part of the brains trust but I'd be having a look at the water temp sensor.
    205GTI - 8 valve, single cam coolness.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    The injectors might be bleeding off pressure and it needs a few cranks clear the fuel before firing.
    Does it blow a touch of black smoke when it does fire or does it just start normally ocne it starts?
    Is your fuel cap a venting type? If so, does it actually vent?
    9,008
    All good questions, mistareno. I guess this is what I was interested in hearing, the symptoms I should be looking for.
    I think the possibilities in general speaking are two
    1. Leaking injectors as you mistareno suggested (not sure why it starts instantly when cold in this case though).
    2. Heatsoak of some electronics, possibly the tacho relay
    I will look for the symptoms you suggested, and also will try to start up with a cold tacho relay (I have a spare good one) which I will replace just before cranking in such situations.
    If it turns out the injectors leak, is it possible to repair them? Or just have to replace?
    And if I have to replace them with used ones, how do I check to make sure these aren't leaking themselves? Plug them to some power source and see?
    I don't get the suggestion about the coolant sensor, can you elaborate DjB8V?
    8V'ville
    919
    I had troubles with cold start fuel mixtures with a previous car. It turned out to be a dodgey water temp sensor and you mention sometimes on hot days it was worse.
    But now that I think of it, it wouldn't be the case with a 205. Pay no attention to my first post, put it down to looking at AF while I'm at work and not thinking straight.....
    A leak in the fuel system sounds good to me, nice work.
    7,483
    non-return valve on the fuel pump leaking?
    9,008
    I think there's equal chances of any of these issues being the problem. See, that's why people give up. Too many issues to chase. Well, I'll see what I can do and report back. I guess a fuel pressure gauge would be good.
