307 Front end Shudder
Results 1 to 11 of 11
    Aug 2002
    Tamworth
    80
    Default 307 Front end Shudder
    Hi,
    I have a 2002 2.0L 307 with 180Ks on board. Never-the-less it is in excellent condition, except for a momentary shudder when I take off.
    Thought it was clutch at first, but it doesn't always do it. It never does it when pulling a trailer or under a load or starting up hill.
    Never does it with slightly higher revs to start.
    It feels like axle tramp, or gearbox mount or suspension bush is worn.
    It has just passed rego and no bushes were reported as worn.
    Is there a known problem, or does anyone have any useful suggestion?
    Leigh
    Sep 2003
    North Parramatta
    4,008
    Hi Leigh,
    Would this be a 2.0 petrol or diesel engine?
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Aug 2002
    Tamworth
    80
    Default 307 Shudder
    Thanks Simon,
    It is petrol.
    Just had another thought.
    I recently had the spark plugs changed and the shudder was gone for a few weeks.
    Could it be the plug coils?
    As an aside, went to local Peugeot dealer to change the plugs, that I was supplying and nearly fell over when quoted $280 to change them!!!!!! Needless to say plan B leapt into operation.
    Great car, lousy Dealership!
    Thanks,
    Leigh
    Dec 2005
    HOBART
    1,265
    Quote Originally Posted by Leigh Wilson View Post
    Thanks Simon,
    It is petrol.
    Thanks,
    Leigh
    Be thankful you don't have a 406 V6. The "early" motors have coil packs - currently $220 a set on eBay (about $400+ from the dealers I believe). Later V6 motors have individual coils at $110 each unless you can find a good deal on eBay. The rear bank requires the removal of the inlet manifold. Luckily plugs dont need replacing very often.
    BUT one wants to be certain that's the problem though before forking out any money.
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Feb 2002
    Tamworth NSW
    496
    Icon7
    Hi Leigh,
    I think the forum have suggested the most obvious & indeed it could still be that it is electrical in nature.
    My daughter's 206 GTi has a similar issue that is related to a worn engine / gearbox mount. This makes the symptom reasonably repeatable & is a relatively low cost fix.
    Contact me "off-air" any time for a catch-up.
    Kim.
    Sep 2003
    North Parramatta
    4,008
    It could be - there is only one coil pack that sits over the top of all 4 plugs, but it would be an expensive guess.
    Does this only occur when the engine has been sitting cold for a long time, or whenever the engine is run?
    For info, it's the same engine as KIMDEB's daughter's 206 GTi.
    Simon
    Aug 2002
    Tamworth
    80
    Default Shudder
    Hi Simon,
    Engine temp doesn't seem to be a factor.
    First start in morning may or maynot do it. Usually not.
    Thinking about it, it is probalby most noticable when the car has warmed up.
    Thanks,
    Leigh
    Apr 2011
    brisbane
    23
    first move, go check that your engine software is up to date.
    dont even worry about the spark plugs yet.
    and also:
    Quote Originally Posted by pugnut1 View Post
    WHO CARES??? IDIOT
    Aug 2002
    Tamworth
    80
    Default shudder, shudder.
    Thanks,
    Great idea.
    Shall get software checked.
    Leigh
    Fellow Frogger! Meggsy's Avatar
    351
    I would still look at the top engine mount I had similar issues on a 406 and the top engine mount and stabiliser bar mounts needed replacing
    Good luck
    Meggsy
    Current - 4007HDi
    Had - 407 HDI 406 SV 404, 504, 505 GR and STI. 405 GR ( carbie version) STI, MI16
    And an Austin 1800
    Learnt to drive in 203 Convertible and a 403 SW
    NSW
    4,918
    My C3 has a slight low spot after you start it when its cold. After it warms up its fine. Is this what your talking about?
