205 exhaust corrosion spots?
Results 1 to 9 of 9
    Dec 2010
    canberra
    206
    Default 205 exhaust corrosion spots?
    hi guys im takeing my 205 gti in to get a road worthy some time next week, but ive noticed a leekind sound towards the front of the car. i cant look under the car because its very low and my ramps are taken by the 405 mi16. so im a bit stuck. hhahah
    i will have to take it into an exhaust shop so they can lift it and change it. but are there any common spots to get a leek? just so i know
    and how much should a new system cost?
    any suggestions for a good one?
    im also looking into getting a twin tip muffler as featured on pugmonkeys? 205.
    but a slightly smaller one may be in order. ford focus st/ xr5 turbo?
    cheers
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,428
    The Manifolds are notorious for cracking. They sometimes sheer the joining bolts and can leak from the flexible join ( the correct name eluding me right now ) They can easily be welded up ( the manifold that is ). Should not cost or take too much time/money
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,879
    Cam
    I had a quote for around $100-150 to weld but the man wanted it with the head to make sure he welded them true. Purchase second hand one here instead.
    Feb 2011
    182
    When mine cracked I was told because it was an old cast iron manifold that'd been through many thousands of heat cycles with a crack full of carbon deposits it would be near impossible to weld. I found a 405 replacement, based on recommendations from the brains trust.
    Fellow Frogger! frog's Avatar
    Feb 2006
    600
    The knitted wire mesh/conical exhaust gasket might be leaking? They don't cost much.
    Jun 2011
    Brisbane Qld
    20,879
    The crack in the manifold in mine was a visible line.
    The gaskets are like this
    http://www.ebay.com.au/itm/PEUGEOT-1...item415f9a7a86
    9,437
    Quote Originally Posted by FIVEDOOR View Post
    Simply machine the face of the manifold flat after welding.
    Otherwise plenty of 205 Si and 405 nanifolds around that are uncracked.
    Graham
    Dec 2010
    canberra
    206
    so will a 405 mi16 one fit?
    cheers
    Jun 2011
    Brisbane Qld
    20,879
    This one will fit
    205 GTi Exhaust Manilfold
