P306XR engine dead??
Results 1 to 2 of 2
    Jerangle
    784
    Default P306XR engine dead??
    Hi,
    the 306 has been parked for a few weeks,a little rain and now it won't start.
    No fuel pump,activity - no power to pump-pump works when hot-wired.
    No spark- dead.
    all fuses good.
    i had this once before and came back later and it started.
    *Where is the relay concerned with this?
    Haynes manual is not much use ,no details on the relays.
    Can someone send me fuse and relay set-up picks?
    Anyone been down this path before?
    Fuses by the battery box all good.
    Regards
    Cas
    Jerangle
    784
    Default P306 fuel pump relay location?
    Just located the ECU relay, plug fault.
    Now have spark.
    *Where is the fuel pump relay?
    1.8 XR
    Any pics of the relay locations?
    Now have it running with hot-wired fuel-pump
    Cas
