Pu4 403 clutch plate replacement
Results 1 to 25 of 28
    Feb 2012
    Malaysia
    175
    Default Pu4 403 clutch plate replacement
    hi guys, need some help here... my 1959 Pug 403 needs a clutch replacement I guess, seems to be having difficulties climbing slopes...
    the workshop manual indicates that the whole rear diff and long shaft has to be removed in order to get to the clutch.. anyone has replaced the clutch plates before, can it be done by any other simple method like removing the engine?
    Fellow Frogger! Molerpa's Avatar
    Jul 2005
    South America, Argentina, That country that looks like hanging from the map... just about to fall...
    492
    Don't exactly know the 403, but yes the 404 (older) with same gearbox than yours, C3-B (although not same engine) can remove engine and replace clutch. Or, you can remove "all what is behind" ... is your choice.
    As you don't have power steering and/or A/C, I prefer to take out the engine, and not all the rear end, suspension, yada yada yada things on the back.
    If you can, and you have someone that can adapt the "Fork" with the BA7 one, so you can use a real ball bearing and not the graphite original bearing, better.
    thanks kiwia110 for the confirmation of "fork".
    Quote Originally Posted by luthier View Post
    It is simply impractical to expect a petrol motor to get through too much water. That's why God invented diesels.
    Sep 2004
    Tamworth UK
    624
    [QUOTE=Molerpa;1031348
    ¿Fork? is the correct term for the rocker arm that presses the clutch press?.[/QUOTE]
    Yes correct term, clutch fork
    Gardenvale
    89
    Default 403 clutch removal
    I have done it a number of times , can say I found it much easier to remove ( really only disconnect and roll back a few inches ) the tail shaft( torque tube ) and rear axle. If removing the engine , much more to disconnect and fairly difficult to line things up when putting it back in.
    Apr 2005
    Gundaroo
    124
    I always remove the engine to replace the clutch because I find it easier overall if a little longer (but it does not take long to remove the engine from a 403).
    I have also replaced the clutch by rolling back the rear axle, undoing the torque tube and removing the gearbox from underneath. I found this much more difficult because I cannot raise the car off the ground far enough to get enough working space.
    Any way that's my opinion for what its worth!
    If you need a clutch kit I purchased a clutch kit (pressure plate and driven plate), last year I bought a clutch kit from the Classic Car Garage in the US ( www.classicgarage.com/pe403clset.htm ); their current price is US$109.96 and 6 months ago the freight from the US to Australia was US$85. I think this is cheaper than European sources I have seen recently. Their kit does not include a thrust bearing
    If you want to fit a ball race clutch bearing release bearing (instead of a graphite release bearing), Der Franzose in Germany sells a ball race version for Euro18.90 plus freight. ( http://www.franzose.de/en/Peugeot/20...lung/ANR72551/ ). I bought one recently and it looks very good - will fit soon.
    If you already have the parts you need just ignore the above info re parts. The internet makes restoring or keeping old cars running so much easier (provided you can wait for parts to arrive that is!).
    John T
    SWOTR
    3,627
    I've always removed the engine when replacing the clutch in a 403. The main reason is that I thought it would be awkward removing and replacing the gearbox while laying flat on my back under the car.
    19,211
    Quote Originally Posted by Peter Chisholm View Post
    I'm with you Peter. Same as the 404. You can access nearly all the bolts you need to remove an engine without crawling under the car.
    You do need a winch with support point or an engine crane to lift the engine. An engine leveller makes it easier, as does jacking the front of the gearbox.
    If you don't have this gear moving the diff back is easier
    Feb 2012
    Malaysia
    175
    Default thanks
    yeah man thanks for all the info, probably have the engine removed. Some parts are still available here but probably covered with thick dust.
    Fitting the fork sound interesting, is it just a straight replacement or does it require some modification?
    dan.
    19,211
    Quote Originally Posted by peugeotnut View Post
    dan.
    Looking at the francoze image ball bearing thrust I think it's a direct replacement for the carbon thrust.
    Make sure you get the two retaining clips with it.
    If you remove the engine, don't forget to take the oil breather off the engine. I always used forget!
    Apr 2005
    Gundaroo
    124
    Having actually purchased the Francoze ball bearing thrust and held in in my hand, I can confirm that it is a direct replacement for the graphite thrust and does not need a 404 clutch fork. However, Francoze did not supply the two retaining clips. Must search their site to see if the clips are available.
    John T
    9,259
    Yes of course, pull the engine out.
    You need to remove the lower sump first though.
    Graham
    9,259
    Quote Originally Posted by JohnT View Post
    John T
    You can't use a plain ball race as it slides across the surface of the throwout pad on the clutch plate and will stick after a while, the BA7 arrangement keeps the bearing in line.
    I believe you can buy carbon coated ball races for this purpose.
    Graham
    Dec 2010
    Mangonui NZ
    82
    Done this several times recently to work on g box which wasnt too bad as i have a hoist BUT for clutch replacement only engine out is more straight forward & no need to disconnect brakes & resultant bleeding & dont need to lift from below etc. All my 403 engine extractions OK with sump still on.........a tight squeeze but manageable!
    Oct 2003
    canberra
    856
    engine out is easier,
    mind you don't crush the brake line if attempting engine remove with sump on
    support the gearbox while extracting motor and while engine out
    Northern NSW
    1,075
    Personally I think it's far easier to take out the gearbox and roll the diff back.
    If you look at the number of things that need disconnecting I think this is far easier than engine out.
    It's handbrake cable, shocker tops, stabilizer bar, rear torque tube bolts, rear gearbox mount, and then roll drive shaft out of the way.
    Then it's clutch mount and gearlinkages , starter, speedo, engine gearbox plates and then gearbox to engine bolts and you're in. The gearbox is light enough to be supported on your chest as you get it down, so all you need is to lift the back of the car body a bit.
    The other way it's all the cables ,[throttle, choke, air cleaner, dizzy, oil pressure, temp sensor, petrol, ground from battery, ] electrical and mechanical, the exhaust manifold and the exhaust where it bolts to the gearbox, the starter, the engine mounts, probably small sump, radiator, bonnet, engine to gearbox bolts, support gearbox, and an engine hoist. When you put it back you need a new exhaust gasket, gasket for sump and crank vent.
    Plus you either need a hoist for the engine or hire one.
    The first way requires no gaskets and only moderate jacking of the rear end.
    Jan 2012
    Murrumburrah
    50
    Having done both, Removing the gearbox isn't bad if a) you can get the back up high enough b) fit two rims without tyres to roll the assembly back c) make a simple cradle to drop in the floor jack to hold the box on the right angle still a bugger no matter which way you come at it, tho better than an R12!!!
    SWOTR
    3,627
    Although it's a long time since I've worked on a 403 I remember my brother and I being able to get an engine out in 20 mins. We never removed the lower sump and I think we unbolted the exhaust manifold from the engine and re-used the old gaskets with a coating of whatever.
    From a safety point of view I'm still not a fan of doing it the other way - rear axle and gearbox out. Although the gearbox may not be particularly heavy, the older I get the more cautious I become. I think I'd rather be working in the engine bay than laying under a car juggling a gearbox.
    To each his own I suppose.
    Feb 2012
    Malaysia
    175
    Default got the engine out
    got the engine out, found the problem was with two off the presure plate springs, also found out that I have a broken distributor clamp, checked the main(050) and conrods(std) bearings. Any idea where I could get a distributor clamp.
    Oct 2003
    canberra
    856
    are you referring to the clip that holds the cap on ?
    if so look art other makes of cars with dissy are similar
    Oct 2003
    canberra
    856
    if so look at other makes of cars with dissy are similar
    9,259
    I have available the alloy distributor piece that fits in the block.
    Graham
    Feb 2012
    Malaysia
    175
    Default yup the alloy piece.
    yes it's the alloy piece, hope i attached the pictures correctly.
    Attached Thumbnails Attached Thumbnails Pu4 403 clutch plate replacement-clutch-clamp.jpg
    Feb 2012
    Malaysia
    175
    Default nope
    Quote Originally Posted by alpine View Post
    not that clip, anyway have attached the picture
    9,259
    Yes, have that I also have the clip for the pressure plate.
    Graham
    Feb 2012
    Malaysia
    175
    Default 403 pressure plate = Alfa 1300 pressure plate
    fyi....
    just found a new old stock pressure plate labelled Alfa Romeo 1300, only difference is that it has 9 springs compared to the 403 that has 6 springs.
    also found the clutch bearing with a layer of carbon labelled 404/504. but i will stick to the original i configuration I guess.
