XU9 engine musings
Results 1 to 25 of 44
Like Tree2Likes
Thread: XU9 engine musings
    9,000
    Default XU9 engine musings
    I have a DFZ in my car which is really nice and pulls like a train.
    I have a DKZ (Si car) in my spares car. Is there any point swapping the two? Apart form the academic task of finding the actual shape of the Si engine (never seen it run).
    I have read on the Puma racing site that Si engines are more likely to be within specs than the GTI, is this true of Aus cars as well?
    And lastly, how hard is it to swap the DFZ dizzy to the DKZ engine? I suppose there's no other mod necessary?
    ACHTUNG ALLES LOOKENPEEPERS
    9,261
    Si is an Australian model, how would Puma know anything about it?
    Si engines aren't DKZ they are BDY, BDY is 1600cc monopoint and DKZ is 1900 multipoint.
    Yes a DKZ will bolt into an Si and has the same head but that doesn't mean it is the same engine.
    Graham
    9,000
    Okay, so what is the answer to whether or not it's worth anything changing over and what else is going to have to be changed apart form the dizzy?
    Fellow Frogger! spar's Avatar
    sunny coast
    263
    are you wanting to replace the jetronic with the motronic si unit?
    AFAIK there isn't a way to hook up the si motronic to a multi point system and it would be a downgrade to go single point injection.
    1990 205gti 8v, sv1000, zx6, sv650, zxr750, rgv250, austin 1800, fiat 124ac, fiat x1/9, 76 rd350, 124bc, lancia beta, yz125G, yz80h, yz50g, gtmx80c
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    919
    An Si motor has a much more restrictive induction to. A GTI inlet manifold would be the way to go on a Si motor.
    If not, stay with the DFZ. My DFZ pulled awesome until I stopped driving it (lousy headgasket)
    205GTI - 8 valve, single cam coolness.
    9,261
    Quote Originally Posted by spar View Post
    Si has Marelli management.
    Why put in a 1600 instead of the 1900, so no,
    Graham
    9,000
    No, I would keep the engine management and intake/exhaust.
    Just to see if the Si engine has survived better (it seems in pretty good nick) than the GTI. Both are unknown quantities, so no real difference, I guess.
    9,261
    So why can't you start up the Si engine in its own body and then do a compression test?
    Sounds like you need something to keep you busy.
    Graham
    9,000
    That's true.
    I can't start it up because I destroyed the wiring to re-wire the GTI so the ECU is no longer connected to the engine amongst other things (and a lot of the wires have been taken away), but I can still do a compression test. As you know though this is not the entire story of an engine.
    And come to speak of it, is there any recommended way to store an engine so valves don't rust, seals don't dry up (water pump) etc.?
    I was just wondering if there is any chance this Si engine is even better than the GTI engine I am using right now, given that is a newer car (possibly lower mileage) and looks like it has very well taken care of.
    7,483
    This is a most confusing thread.
    Do you have a DKZ in an Si shell, fed by Si management, induction etc.?
    9,000
    My mistake, I thought it was a DKZ.
    No, I have an Si car with its original engine (a BDY as you said, I checked). Everything stock.
    Look, I have two cars.
    A GTI with a replacement DFZ engine (bought S/H off someone here).
    An Si with everything original, spares car, BDY engine. Car bought as a write off (crashed LH front), but in very good shape otherwise and looks very well maintained.
    The GTI is my daily driver, but it got there thanks to all the bits I cannibalised off the Si. I did reuse some of the wiring off the Si, but I have used it to rebuild the GTI loom, not just swap over the wiring form one car to the other.
    I think you are confused because you think I swapped over loom and parts. That is not possible as you know. What I did was replace individual wires (tried to keep the numbers correct) because the GTi loom was frayed and cracked and messed up generally speaking. It was a nightmare, but I did it in the end (took me three months), so now I have a nice new loom made up by wires borrowed from the Si (literally pulled out of the connectors and replaced in the correct connectors on the GTI, keeping the wire numbers), wires I made up myself to replace what I could not find in the Si loom, and some wires I added from scratch because I did not find originals on either car (sunroof wires).
    The ECU wiring loom on the GTI was not changed, apart from replacing the injector wires with silicone insulated oxygen free wires and new Bosch connectors.
    Wires from the Si ECU loom were "borrowed" to replace similar wires elsewhere in the GTI loom, because they have the right (narrow) spade terminals you can not buy.
    Clear as mud?
    7,483
    Why don't you go back and edit the first post then? Change DKZ to BDY.
    If you want to make the most of what parts you have, put the BDY head on the DFZ block, with the DFZ cam.
    8V'ville
    919
    if you do the head swap you might as well put a cam in too and really power up.
    9,000
    Thank you Peter, that is in the wings, but I already have a DFZ head which I understand can be machined down to mimick a BDY head, and I actually have a DKZ head (which I understand is identical) as well, so it's not really necessary to pull apart what could be a perfectly good engine.
    7,483
    T but I already have a DFZ head which I understand can be machined down to mimick a BDY head, .
    not sure where you got that from. The DFZ head is a bit of an orphan. It has 39/33mm valves 105mm long, compared to 41.5/34.5mm 108 long in the BDY/DKZ/D6B head. Whilst it is possible to skim a massive 2mm off the head to reduce the chamber volume, you only create more challenges by retarding the cam timing.
    9,000
    Sorry, I forgot the valves are smaller, you're right.
    And the reason I bought the DKZ head was the timing issue.
    Anyway, I still have the DKZ head and a DFZ cam, so there's no real need to pull apart the BDY engine (not that I have something against it).
    That means I need to buy some valves then. Can these still be bought new?
    What about the pistons, I understand the DKZ pistons are different to the DFZ too? Can I buy these new?
    7,483
    Why do you need valves? Is the DKZ bare? I'd just use the BDY head if that was the case. Do you have a DKZ cam? They're more desirable than a DFZ cam.
    Why do you want DKZ pistons? You have a working DFZ and another set of identical pistons in the BDY. The DKZ piston has a 15cc dish compared to just 9cc in the DFZ/BDY.
    9,000
    Yes, the DKZ head is bare, no cam, no valves.
    Nope, no DKZ cam.
    Am not sure if the DFZ pistons are reusable (most likely/hopefully they are). I assumed the higher compression of DKZ engines came from a higher deck/smaller dish or a combination of both.
    8V'ville
    919
    you said your dfz engine is still strong, so why replace the pistons? you will get more compression with dfz pistons than the dkz items. the pistons going into my new motor aren't new ones. as long as your dfz items are in good nick you'd have to have rocks in your head to go out and buy new ones.
    7,483
    It's more likely to have liner wear than piston wear. As you have a second set of pistons/liners in the other car you're sorted anyway.
    The DFZ has an 11mm deep chamber, 49cc. The other type of head has a shallower 8mm deep chamber, 34cc. Thus the difference in valve lengths.
    You can see that 34cc + 9cc is better than any other combination for compression.
    It may even be that the D6B piston is 15cc and the DKZ is 16cc.
    9,261
    That's true.
    In one word, no, the Si (BDY) has 65 kw and 128 nm of torque the DFZ 75 kw and 143 nm of torque.
    The DKZ has 90kw and 151? nm of torque.
    Didn't you say the DFZ was going great?
    Graham
    9,000
    Yes, Graham, but that comes without any term of comparison. I have never driven one fo these cars new. That is why for me the DFZ is going great, but who knows how much better it could go with a rebuild or even a spec up to DKZ. Which is where the BDY comes in. What if the DFZ has lost some of its power, enough to bring it down below what the BDY may have lost itself? that is the question I would like to explore.
    But it's not really a plan. The BDY engine can always be a stand-in while the DFZ gets rebuilt if it turns out that is the best way to go.
    My main aim is to end up with the best engine I can without any serious mods. If I had a DKZ engine, I would use that. I have apparently enough parts that with a minimum expenditure I can build an engine at DKZ specs. All I need right now apparently is the valves and a DKZ cam. I did not mention, but I have a good GTI crank, the pistons, sleeves and conrods I saved from the original DFZ engine and hopefully will be able to reuse some of that stuff. I would only get new pistons to make sure I don't have any problems. Sleeves look very good to me, but I will measure them of course, and if need be I will replace.
    1000+ Posts djvu205's Avatar
    1,402
    you should just buy my spare dkz motor and all you problems will be solved!
    9,261
    You have the right valves in your BDY engine but you would need a set of DKZ pistons to build a DKZ spec engine.
    8V'ville
    919
    Compression check.
    This thread is getting a bit repetative.
