205 rear camber
Results 1 to 25 of 41
Thread: 205 rear camber
    Dec 2010
    canberra
    206
    Default 205 rear camber
    hi guys , i have seen some 205s in picture gallerys with rear camber.
    how do i do it?
    this is a teen speaking so i wan the car to look real sporty for friends and general public, ahaah
    cheers
    I might be slow... DRTDVL's Avatar
    Auckland
    1,288
    The camber is fixed due to the trailing arm setup.
    You can get different arms from other models (306, 309, ZX,etc..) that will change the toe and camber. If you do a search i posted up a listing of them all i stole from 205 GTI Drivers.
    I've seen refer to "SBC negative camber stub axle" but can't locate SBC on the net to check them out.
    You can't run massive rear camber because the wheel will rub the inner arch especially with 6.5 inch wheels on there.
    Dec 2010
    canberra
    206
    i really thought i had to convert it to rear coilovers ahah.
    cheers
    from the little frogg.
    Auckland
    1,288
    There are a bunch I people converting the rear to coilovers for better rear wheel control / travel.
    7,483
    Heat the trailing arms up half way along with an oxy torch and bend to desired angle(s).
    Lilydale, Melbourne
    2,095
    Hope he doesn't take you seriously!
    John W
    1974 Peugeot 504 TI
    - now on the road
    1,376
    I think most of the 205's you see with negative camber are the ones that require a rear beam rebuild due to worn bearings and worn away trailing arm shafts. (see my last post)....
    Moo
    1000+ Posts pgti6's Avatar
    May 2001
    1,618
    You could try this company in the UK-Bridgecraft Engineering Services and Products. Have a read here-
    http://www.306gti6.com/forum/showthread.php?id=144900
    of the services they offer.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    7,483
    Quote Originally Posted by peujohn View Post
    Why? That's how Parry car was done. Four owners (three are still active AF members) over 15+ years have belted that rear end around Australian circuits. Here it is when I owned it.
    Far North Queensland
    1,494
    And what was the verdict Peter?
    Does a bit of negative camber on the rear imoprove handling?
    How much neg camber would you recommend?
    Paul
    A straight is merely the distance between two corners.
    Current: Peugeot 205 GTi Mi16 1987
    Peugeot 205 Si, one red one silver, both 1991.
    Peugeot 504 Wagon, V6 and 5 speed gearbox.
    Isuzu (Holden) Rodeo, 4WD dual cab, extended chassis.
    Past: Goliath, Isuzu Bellett, Austin A30, Peugeot 203, 403, 404, 504,505.
    Lilydale, Melbourne
    2,095
    I actually thought you were tongue in cheek! Heating up and bending suspension components doesn't sound like a good idea to me. But there you go.
    John W
    1974 Peugeot 504 TI
    - now on the road
    1000+ Posts parry's Avatar
    Sydney Australia
    1,329
    The camber Peter is talking about is 1.5deg neg, dont know how they got it that even, but the toe is way out. Either way the car on the track is so planted in the rear.
    90 205 Gti Cherry Red(Track Car)
    2009 207gti
    1985 505gti (Shitbox Rally) Sold
    PBs:
    Oran Park: 1:27:9
    Wakefield: 1:05.6 (July 2015)
    Eastern Creek: 1:54 (8v) 1:48 (16V)
    Mt Huntley: 34.44 (2004 stock 205)
    Ringwood: 35.06 (30/10/2005)
    Winton: 1:33.6 (2017)
    1,494
    Quote Originally Posted by parry View Post
    Thanks for that Parry.
    Any problem with tyre scrubbing or uneven wear?
    Paul
    Sydney Australia
    1,329
    Quote Originally Posted by 504-504-504 View Post
    Paul
    Our race car is down to 750kg so the there is not much weight over the rear wheels I hardly get any wear on the rear let alone uneven wear. The rears down last long as I normally swap to the front when the fronts wear out.
    I am gathering you have a street car, I would recomend other suspension changes to the rear before you think of rear camber. You need to remove the 205 tendancy to liftoff oversteer as there is no way to catch it. Solid rear mounts and stiffer arb and torsion is the way to go.
    2009 207gti
    PBs:
    Oran Park: 1:27:9
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    919
    + 1 on the solid mounts.
    My 205 is a daily/road car and the solid mounts are great
    205GTI - 8 valve, single cam coolness.
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,370
    +2 on the solid mounts.
    You can fit a shim to the stub axle which gives camber. Its the same way the Clio Cup runs rear camber
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Nov 2003
    Bondi
    3,370
    91 205 Si
    87 205 GTi Race Car
    NSW
    627
    I have run against parry and peters cars.
    My car has a standard setup at the back with extra track and solid mounts. They haven't caught my times yet. Why change something that works ok?
    Adrian Wuillemin
    7,483
    11.5
    11.8
    12.1
    I sense there's going to be some great racing this year.......
    Sydney Australia
    1,329
    11.5
    11.8
    12.1
    Peter, I dispute you 11.8, there is no record of it on Natsoft.
    Adrian official Natsoft best is 11.6
    I am running this Sunday, lets see if records can be broken with an 8v!
    2009 207gti
    PBs:
    Oran Park: 1:27:9
    1000+ Posts djvu205's Avatar
    1,402
    Adrian how/why the extra track? im about to rebuild a rear beam for mine and thinking of using s16 trailing arms i have to gain a slightly wider track.
    it would be mainly for asthetics and having the wheel fill the guard better, but i have also heard there are other benefits like more toe and more camber
    7,483
    You're right there is none. It was 12.7........
    http://www.natsoft.com.au/cgi-bin/re...0/2008.WAKE.S1
    and something else I found in the archives......
    http://www.natsoft.com.au/cgi-bin/re.../2007.ECR.S1.Y
    I guess it's a bit like fishing. I thought this was in the 25's too.....
    http://www.natsoft.com.au/cgi-bin/re...3/2008.ORAN.SS
    1,494
    Yes Parry its mainly a street car but I would like to do a couple of sprints and hillclimbs (not much available up here).
    Its a GTi Mi16 with eibach front springs with the rear lowered to match. Koni red all round but standard front anti-roll bar and std torsion bars and anti-roll bar at the back.
    Not game to push it hard enough to get liftoff oversteer on the road but it tends to understeer on full power corners.
    With the modifications you suggest should any changes be made to the front Anti-roll bar or would that complicate the matter?
    Could be up for a rear beam rebuild so will go for solid mounts at that time.
    What amazes me is the agility of the Red Si automatic I have.
    Fitted it out with pepperpots with some rather ordinary tyres but it handles beautifully, very neutral.
    No way I will even approach its limit on the road. Obviously the Gti can corner harder but the Si just feels so much more controllable.
    Paul
    “A straight is merely the distance between two corners.”
    NSW
    627
    The extra rear track was achieved with spacers between the hubs and the wheels. Loger wheel studs were used. Think it was 25 to 30mm.
    To be fair Peter and i have not run at wakefield since it has been resurfaced and some of the ripple strips altered. Thats worth over a second.
    Slicks are worth another 2 plus seconds.
    Your 8 valve times are quick. It will be an interesting year.
    Adrian Wuillemin
    7,483
    I was reminded that the 11.8 was at a CLA Training day, unofficial of course. You can also get a slightly wider track and toe in by using 306 trailing arms. Of course when using the oxy you can dial in what ever toe in, camber and track width you want.
