rechipping a 2.0 HDI diesel
Results 1 to 12 of 12
    435
    Default rechipping a 2.0 HDI diesel
    Has anyone rechipped a 2.0 HDI here. I just got a 407 HDi
    I hunted around for a 2.7tt 407 (150Kw) and couldn't find one at the right price so I bought a 2.0 one (100Kw) I see on the web you can get 20kw more (or so) with a chip. So has anyone rechipped one (or reflashed) If so where, when and approx $$$
    Apr 2004
    SOMERSBY NSW
    21
    Icon7 407 HDi chip
    435
    yes - looks good
    Fellow Frogger! andrepug's Avatar
    Victoria
    454
    local source;
    http://www.chiptuning-australia.com....s-peugeot.html
    http://www.dpchip.com/
    Also for more talk on this see forums for 4WDs as those owners are more likely to be discussing chipping their beasts!
    eg;
    http://www.performanceforums.com/for...-Diesel-Tuning.
    http://www.exploroz.com/Forum/Topic/...ower_Chip.aspx
    Fellow Frogger! jurgen_s's Avatar
    Belgium
    707
    stay below 370 nM of torque and it will be ok. Go more and you will ruin the fly wheel, clutch and gear box.
    www.peugeotforum.be
    Belgium Peugeot Club
    Dec 2002
    CANBERRA
    400
    Hi, I haven't touched my 407 hdi but chipped my 2.5 litre R51 Nissan Pathfinder years ago.
    I brought in a TDC Technologies PowerBox from the US (German made) as the price was so much cheaper than the alternatives here. The box offers a range of power setting but I've kept it quite conservative. Very happy with power and torque improvements, particularly for towing, and economy is probably about the same.
    After a couple of years I started to get engine warnings and drop to limp home mode. The box turned out to be faulty so I just bought another one.
    Link to site below. I bought via eBay.com.
    http://www.tdc-technologies.com/
    Jim
    Dec 2002
    CANBERRA
    400
    Peugeot isn't listed on the site but is available. Link to a US listing and you can go to the store for more info.
    http://www.ebay.com/itm/Power-Box-CR...item3a6ab3a781
    Apr 2004
    SOMERSBY NSW
    21
    Icon7 Racechip for 406 HDi
    I was impressed, so I bought one for my 8 valve HDi. So far I'm very impressed with the company and the results with the chip. I going to check it on a dyno, just for curiosities sake.
    It arrived in a week and cost $374. Well worth the $$
    Victoria
    454
    which one did you buy?
    Apr 2004
    SOMERSBY NSW
    21
    I bought the "Pro" version.
    If you buy one identify the plug that fits your fuel rail. It is behind the fuel filter on a 406 and unplugs by lifting the clip and pulling the plug down, loosen the fuel filter bolts so as to gain easier access to the plug.
    Photograph the plug at macro level because there is a slight variation in similar looking plugs.
    http://www.racechip.de/racechip-chip...DI-2898-r.html
    Cheers Ross
    Jul 2004
    torquay vic
    34
    power would be gained by upping the boost i would imagine i had a boost gauge on my 406hdi and by 2000 rpm it was running 20 psi of boost and then holds 20 psi through the rev range i disconnected a sensor for boost and by 3000 rpm it was running 30psi and pulled really hard but then the computer worked out something was wrong and went into limp mode somebody clever could probably change the value of this sensor to bring up the boost up a tad quite cheaply
    Gus
    Gus is offline
    Fellow Frogger! Gus's Avatar
    Jun 2002
    Canberra, Australia
    600
    Does anyone in Canberra have one of these HDi fuel rail boxes that they could lend me for a week? I'm fairly certain there's about $5 worth of electronics in them, and I'd be curious to put one on a test rig and find out whether they have an actual "map" in them or whether they apply a flat scale to the fuel pressure signal.
    Quote Originally Posted by craig latta View Post
    The possible catch with telling the computer it has less boost pressure is that it may correspondingly reduce the fuel injected as well. You'd need to test it on a dyno to be sure you're not just getting hot air (literally!)
