Another AL4 oil change question , which is the drain plug?
Results 1 to 14 of 14
  • 1 Post By con
Thread: Another AL4 oil change question , which is the drain plug?
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    547
    Default Another AL4 oil change question , which is the drain plug?
    Hi
    Yes I tried the search funtion.
    The 307's AL4 needs an oil change so purchased the origional and expensive oil and raised the car on the hoist expecting to see a large drain plug with a smaller level check nut in its center. But what I found was a " normal " Peugeot drain plug ( with 8mm square) , I removed this plug and only 1 litre of oil came out .
    I can not see any thing else low enough to be a drain plug and can see no way to do a level check.
    Am I missing somethging ? Can anybody point out the obvious to me.
    Photos below show the bottom of the box with the plug I removed easy seen by thr trail of oil.
    Which one is the drain and level check?
    Thanks in advance.
    Andy
    Attached Thumbnails Attached Thumbnails Another AL4 oil change question , which is the drain plug?-al4-drain-plug.jpg   Another AL4 oil change question , which is the drain plug?-al4-drain-plug-1-.jpg
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Gone Fishin' Haakon's Avatar
    May 2002
    canberra...
    8,751
    That the only hole they have... You're right to have expected the big bolt with a smaller one inside for the level tube.
    Not much help though...
    Pearl Beach NSW
    547
    If its the only hole they have , how do I get the rest of the oil out ?
    Then check the level.?
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    NSW
    4,918
    There is a real process involved here. Citroen people know how to do it. Post in the Citroen section and you will get more help. Its not an easy thing from what I can make out?
    May 2002
    canberra...
    8,751
    Dunno - yours may be one where they took the "sealed for life" crap really seriously!!
    Sorry - hopefully someone else knows why your one is different...
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    625
    Just a thought, why would it have a level plug since it has a level dipstick ?
    I would have thought that it was the correct plug since it is at the bottom.
    Maybe you need a suction pump.
    Attached Thumbnails Attached Thumbnails Another AL4 oil change question , which is the drain plug?-al4-drain-plug-1-.jpg
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    con
    con is offline
    sydney, nsw, australia
    515
    Andy,
    The following pages from a Factory Manual may help you (hopefully).
    con....
    Attached Files Attached Files
    CC207 likes this.
    NSW
    4,918
    Quote Originally Posted by con View Post
    Andy,
    con....
    As I thought. not an easy process. A Servo mechanic would have no idea when it came to this gearbox. Even the Oil change is cumbersome and time consuming if the person doesn't know what they are doing..
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by Doush_504 View Post
    It's been quite a while since PSA produced a car with an auto that had a dipstick, unfortunately.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Cairo, Egypt
    625
    Quote Originally Posted by SLC206 View Post
    Oh !! I thought it was like in the 406.
    Do they make them "Sealed for life" now ?
    Chadi
    All since new
    Fellow Frogger! callipygous's Avatar
    Jan 2006
    Toowoomba
    797
    The auto gearboxes are 'sealed for life' which is, evidently, 100,000 km. The oil will get replaced next rebuild. Perhaps if the oil were to be changed more frequently... Ahh never mind, just a foolish thought.
    Peugeot 504 Intercooled T04 Turbo.
    Pearl Beach NSW
    547
    Thanks for all the help.
    Con your files were a great deal of help as I was able to determine that my box was differant and I was not going mad! Correct info from A&B Transmission , over the phone very helpfull
    The later AL4's are a little bit differant to the early ones.
    They no longer have the small level check plug in the centre of the 27mm drain plug.
    There is now only a normal sized level check plug , that when removed will allow excess oil to drain , if you wish to drain the whole gearbox you must insert a 8mm Allen key up the plug and unscrew and remove a plastic tube which will then allow the oil to drain.
    This is not a plesant job as you have hot auto oil dripping on your hand while unscrewing the plastic tube. Another step forward in car design!
    The car now has smother gear changes , so well worth the effort and cost.
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by Rally View Post
    Thanks for the info, Rally.
    Presumably, one litre came out the first time because the gearbox was not at the "correct" temperature for the stand pipe.
    Simon
    NSW
    4,918
    Rally where did you have this done on the Central Coast?
