Blocfor washers
Results 1 to 7 of 7
Thread: Blocfor washers
    651
    Default Blocfor washers
    The 504 workshop manual refers to Blocfor washers when re-fitting the diff to the torque tube.
    What're them then?
    504 GL Coupe '73 Silver
    407 HDi Sedan '05
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,439
    Default Spring washer
    Google it.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    651
    Quote Originally Posted by BIGRR View Post
    Google it.
    Tried that.
    407 HDi Sedan '05
    19,211
    Quote Originally Posted by Uffee View Post
    What're them then?
    Blocfor washers are a kind of lock washer. They resemble a thin flat washer with "convex wave" shape pressed into load faces.
    Their first cousin is a belville washer.
    Blocfor washers are used as lock washer when the nut is under a lot of tension.
    They are also used on the gearbox casing bolts and studs of BA 7-4.
    651
    Blocfor washers are a kind of lock washer...
    Thanks for that.
    You wouldn't happen to know what Onduflex washer are as well?
    407 HDi Sedan '05
    19,211
    Thanks for that.
    As you were.
    It appears my description is of a onduflex washer
    http://www.infastech.co.kr/acument/p...lexlocking.pdf
    Back to the drawing board for blocfor washer, which if it's the washer that goes under the torque tube fixings, is a meaty spring washer.
    Funny people these French.
    Edit: I wonder if it's one of the weird inside/ outside serrated washers? My memory of 504s is fading...
    651
    I got that impression from the context but couldn't find any links that confirmed blocfors and spring washers were the same/similar.
    407 HDi Sedan '05
