306 - Mould under headlight problem
Results 1 to 10 of 10
    Fellow Frogger! BradlehGordz's Avatar
    Sep 2011
    398
    Default 306 - Mould under headlight problem
    Hi there froggers!
    I have been looking at this for ages and it's finally got to me! The strip mould under the headlight, on each side it looks like the outer clip is broken on each on, cause them to poke out...
    Does anyone know where I can get these two clips from? Or how I can fix these moulds from poking out?
    Brad
    P-Plater
    Obsession for le Peugeot!
    Current:
    '98 306GTi6 + Bianca white+ Sun roof.
    Previous:
    '99 306Style
    I live for the 6!
    Dec 2005
    HOBART
    1,265
    Quite often these are called eyebrows. Wrong side of the eye, but who cares!
    They are available at various peugeot wreckers, as well as the plastic clips
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Sep 2011
    398
    I was going to refer to them as eyebrows but I didn't know for certain :L haha and thanks for that
    P-Plater
    Current:
    Previous:
    '99 306Style
    I live for the 6!
    Lismore
    133
    I got em new about 3 years ago Auto France I think - now Dapco
    Member 406bliss's Avatar
    Feb 2005
    69
    Default cable ties
    Yes, it drove me crazy too, pushing it back in place every time I walked past.
    When I had to replace a driving light I discovered that if you take the front bumper off... not that hard,
    you can use a small cable tie on each side instead of the breakable hard to get clips. Sweet (and permanent ) relief from this aesthetic annoyance.
    Good luck...
    Jun 2011
    Tasmania, Australia
    215
    Default Grill fixing clips 306
    These grill fixing clips should be readily available from any authorised Peugeot dealers parts department for around $5 ea.
    The 306 N5's (7/97 on) are different to N3.
    The N5 type are also available from "Paragonpug1" in the UK for $2.60ea. plus $2.90 post with extra ones sent for almost nothing extra. Buy several at a time !
    The trick to fitting is to attach the clip to the "eyebrow" first then snap onto the front of guard .
    Alain
    Sep 2011
    398
    Quote Originally Posted by 406bliss View Post
    Good luck...
    Would you happen to know the steps for this procedure!?
    Brad
    P-Plater
    Current:
    Previous:
    '99 306Style
    I live for the 6!
    Jun 2011
    Tasmania, Australia
    215
    Default 306 headlight mould fix.
    Hi Brad
    Assuming yours is an N5 mod. lift the bonnet and remove air intake duct screw on RHside (torx T-30 from memory)
    Remove the 4 inner plugs from along top of grill locating plugs (2 small screw drivers) and remove larger plugs carefully, then the screw under or beside the centre badge
    Very gently prise (flex) out the grill complete with eyebrow on the affected side.
    If the eyebrow is securely fixed (usually are due to dirt build up) spray along under headlight with WD or soapy water and wriggle about for a bit. (they are fixed to base of headlamp by 3 expanding clips which you don't want to break) If you have problems releasing these try squeezing these tangs from under bumper if possible with needlenose pliers or a long small diam. screw driver.
    Its a good idea to clean the parts once dismantled
    Make sure eyebrow securely fixed to grill, attach new clip to eyebrow and gently feed the tangs back into headlight, then snap the end back into front of guard.
    Voila!
    Alain
    Melbourne Australia
    1,382
    And for the mould try cleaning with White King : rolfmao
    Fellow Frogger! trihardthlete's Avatar
    Oct 2011
    434
    Well bought the clips online only to snap one while putting them on. $15 down the drain, instead used 2 cable ties and fixed in 30 seconds. 406 bliss thanks for the tip.
