504 / 505 GearBox Identification
Results 1 to 7 of 7
    Brisbane, QLD
    117
    Default 504 / 505 GearBox Identification
    Hi,
    I'm trying to identify a couple of gearboxes that I have, and need some more expert help!
    Photos A are of what I think is a BA7/5
    Photos B are what I think is a BA7/4, although the bellhousing appears to be different from other 504 boxes I have seen. It was from a late 504 Familiale retro fitted with a 504 TI motor.
    Any help would be appreciated!
    Thanks,
    Neil
    Attached Thumbnails Attached Thumbnails 504 / 505 GearBox Identification-gbox-a1.jpg   504 / 505 GearBox Identification-gbox-a2.jpg   504 / 505 GearBox Identification-gbox-b1.jpg   504 / 505 GearBox Identification-gbox-b2.jpg
    1000+ Posts Beano's Avatar
    3,142
    Gearbox "A" looks like a BA 10 to me.
    651
    Quote Originally Posted by Beano View Post
    Agreed.
    504 GL Coupe '73 Silver
    407 HDi Sedan '05
    12,264
    yep 10
    GB b is wagon and a 7
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Dec 2002
    Menzies Creek
    2,541
    Agreed with the above.
    Gearbox A is definately a BA10/5, the giveaway is the plate on the end of the fifth gear extension shaft held on by 3 bolts. On the BA7/5 this is replaced by a threaded plastic plug. The bell housing is to suit an XN motor.
    Gearbox B is a BA7/4. It is also for an XN motor, but it is the late (post 1979) bellhousing design, and it will have a rubber seal on the input shaft in place of the earlier oil slinger. (note that the BA7s fitted to diesels didn't get the rubber seal until about 1982).
    You can see how the BA10 wouldn't fit into the rear gearbox mount on a wagon. A custom mount is required.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Brisbane, QLD
    117
    Default Gearbox identification
    Thanks Beano, Uffee, Pugrambo & Scotty.
    Appreciate the collective wisdom of Peugeot enthusiasts. I was told the box I thought was a BA7/5 was from an STI, so perhaps it had a swap sometime in it's life? I was looking for a BA10/5 anyway!
    Neil
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    625
    Quote Originally Posted by Demannu View Post
    This is the one you're talking about, right ?
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
