peugeot 306 head problem
Results 1 to 18 of 18
    Dec 2010
    canberra
    206
    Default peugeot 306 head problem
    hi guys my 306 xr has a blown head gasket and 'maybe warped head' ( ive been told)
    the previous owner had driven it with a hole in the radiator and she over heated and blew. ( also need a new radiator) but ive been quoted 1500-2000 at a couple of places and just for the head gasket change and thats with no garantee that head isnt cooked. is this a fair price? because ive looked around and a full gasket kit for the 1.8 is only 150 bucks or so.
    suggestions?
    cheers from a fellow frogger in need!
    12,266
    Quote Originally Posted by 205lover<3 View Post
    suggestions?
    did you get a quote to get the head machined/straightened ?
    you may need a new/2nd hand head
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    7,483
    Not many 306 XR's are even worth $2000. Be realistic about the value of the car and what it will cost to fix. It may be cheaper just to buy another one! Having said that, also consider just dropping a second hand engine in. They're cheap as chips as well.
    Feb 2001
    Romsey, Victoria, Australia
    4,869
    Its not what the cars worth thats in question but what is it worth to the owner that is the issue.
    Plenty of people spend the value or more fixing there cars because sometimes the devil you know is better than the devil you don't know.
    You can spend 5k, 10k whatever on a another car and still have trouble so fixing what you have is sometimes a better option.
    We have good engines in stock, one has just had a couple of grand worth of rebuild done only just before the car got written off so that engine might get you out of trouble.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Fellow Frogger! Molerpa's Avatar
    Jul 2005
    South America, Argentina, That country that looks like hanging from the map... just about to fall...
    492
    Quote Originally Posted by David Cavanagh View Post
    I don't know who are you referring to
    Quote Originally Posted by luthier View Post
    It is simply impractical to expect a petrol motor to get through too much water. That's why God invented diesels.
    Dec 2010
    canberra
    206
    so is that the useual price for a head gasket change or would it be cheaper to get a new engine FITTED. thats not including a head re-alignment by the way.
    if a new engine is the go how much would a gti-6 or V6 go for?
    cheers
    Feb 2001
    4,869
    Your kidding right?
    Use the KISS pricipal. Keep It Standard Stupid.
    If you want a GTI6 powered 306 I suggest you buy one. If you want a V6 powered 306 then first seek mental help and then build your own.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Dec 2010
    canberra
    206
    ok that makes sence ahahah, how much would a 1.8 i motor go for then?
    cheers
    Feb 2001
    4,869
    cheers
    This particular motor Thats had all the money spent on it we want $880 for. It has receipts for over $2k just before it before it got written off. The head is still clean. Freight to ACT probably $100.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Dec 2010
    canberra
    206
    thanks david i will keep that in mind, i have bought some products to help me along.
    1. chemi-weld
    2. a copper liquid sealant for the radiator
    3. some oil flush just in case.
    but the car is still smoking, not big clouds like before but still a little bit.
    one of the products says to leave the car idling for 15 mins with the radiator filler cap off. and after a while it starts too over flow. then the thermo fans come on and imediately the the over flow stops and sucks the water in, and im not sure where it goes because i am then able to put another 7 liters of coolant/ water in with not fuss. its not going in the exhaust and not going in the oil either.
    i have a feeling the thermostat?
    Dec 2010
    canberra
    206
    can a car run with no thermostat ????
    1000+ Posts Beano's Avatar
    3,149
    Yes...no problem. For a few months is fine, as it is Summer now.
    Dec 2010
    canberra
    206
    so it will just take longer to warm up in winter?
    cheers
    10,949
    1. chemi-weld
    I suspect it will be better long term to get David's engine as offered........ "Products" are "products", and they are patching up fundamental damage/wear problems.
    Best of luck.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Dec 2010
    Wollongong, NSW
    499
    Some comments from an experienced head gasket sufferer.
    1. You are running on borrowed time. This car will come to grief shortly. The chemiweld etc, does not cure a major problem and it sounds like you have a major problem.
    2. $1800 for a head gasket replacement (have to be careful saying head job) is normal. Yes you could do it yourself with a knowledgeable mate for only $350 worth of gaskets and bolts (also new water pump, tensioners and timing belt while youa re at it), but it takes a fair time and is fiddly and possible to make an expensive mistake. You might find a backyard mechanic who will do it for less, but then you risk them stuffing up the timing or something...
    3. A straight engine swap or a car replacement is the easiest and most reliable thing. It will take about 10 hrs to take your engine out and put David's one is and his price is very fair. If you buy one in another vehicle, then add another 5 hrs to get that one out first.
    Head gaskets are disappointing things to happen, but have no quick cure.
    Cheers, Erik
    Dec 2010
    canberra
    206
    thanks guys will check again with some mechanics. if that doesent work out a new engine seems the go.
    cheers and thanks for all the help
    Feb 2001
    4,869
    1. chemi-weld
    Sounds like you have a blown gasket big enough to drive a truck through. Take the thermostat out, it might be stuck shut and that could have caused the blow.
    Put the thermostat in a saucepan full of water and boil it, as the temp rises it will slowly open until the water is boiling it will be fully open. It its not then thats the cause of your problem.
    Don't put it back in but try again with the sealant products but it might to to far gone.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Jan 2012
    Illawarra
    29
    Since buying a 206 GTi, I have a 306XR to sell. Complete Car. Make an Offer.
